Is this normal? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-10-2014, 06:43 PM Thread Starter
1997PSD's Avatar
Quoted: 2 Post(s)
Is this normal?
I was looking at my leaf springs and noticed that they have, what seems to me to be, an odd gap between the two leaves. I referenced the picture to my dads truck and his do not have the gap and we both have V codes up front. Is this normal? or are my front springs showing signs of wear?
2000 F-250 XLT
Twisted Diesel Level II 4R100 w/ V10 Cooler
TS 6 Position w/ PHP Tunes.
4 inch turbo back straight pipe.
Wicked Wheel 2
18in XD's wrapped in 35in Toyo Open Country M/Ts
3 inch PMF shackles w/ Ford X-codes.
Re-routed CCV
Red Head Steering Gear
Isspro A-pillar Gauges.
7 inch pioneer touch screen.
'07 grille and Morimoto Retro'd headlights
'08 side mirrors.
Ranch Hand bumper.
1997PSD is offline
post #2 of 9 Old 07-10-2014, 07:06 PM
Joel's Avatar
Quoted: 10 Post(s)
Mine aren't like that.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 9 Old 07-11-2014, 02:30 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Does the top spring have any cracks in it? Seems like it may be broken since it's spread like that
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 9 Old 07-11-2014, 04:03 AM Thread Starter
1997PSD's Avatar
Quoted: 2 Post(s)
No cracks. Could this be caused by the hangar kit that the PO installed? I believe the front hangar is a 3inch but the rear hangar is stock. Could it be putting a weird strain on the spring?
Sent from AutoGuide.com App
2000 F-250 XLT
Wicked Wheel 2
Re-routed CCV
'08 side mirrors.
Ranch Hand bumper.
1997PSD is offline
post #5 of 9 Old 07-11-2014, 04:28 AM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
I'm guessing on what happened. But what I think happened is your shackle bound up into the frame and your spring had nowhere to go and it bent when you compressed the suspension. Do you have any marks on the frame where the shackle may of hit?
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #6 of 9 Old 07-11-2014, 05:41 AM Thread Starter
1997PSD's Avatar
Quoted: 2 Post(s)
I couldn't see any wear marks, but they could have worn away because the truck doesn't really get used as a "truck" anymore down here in key west . Is it safe to say this is why my truck rides like a 1913 horse and carriage?
2000 F-250 XLT
Wicked Wheel 2
Re-routed CCV
'08 side mirrors.
Ranch Hand bumper.
1997PSD is offline
post #7 of 9 Old 07-11-2014, 06:30 AM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
It's possible. When your at ride height your shackle should be straight up and down. To cause that much damage it would of had to bottom out really hard. To test my theory you could get a go pro and point it to the shackle and hit a few bumps and see if it gets close to hitting. If you don't have a go pro get a few friends and bounce the front end while you watch it. With the bend in your spring your shackle is actually sitting farther from the frame. If you straighten it out it would be closer to touching. Again this is what I'm suspecting what happened. It's hard to tell from a picture. I would take measurements from your shackle bolt on the frame to your bolt For your spring on the hanger and compare your measurements to your dad's truck. I say to fix it you have to replace your springs and possibly move your front hanger forward or get a new hanger kit if your measurements are less than your dad's truck.
01 f-250, Standard
post #8 of 9 Old 07-11-2014, 06:48 AM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
Another thing I was thinking is if the bump stops are still at stock height and it has a 3" hanger kit. If it got bottomed out it would travel farther than it was intended to and cause damage also
01 f-250, Standard
post #9 of 9 Old 07-12-2014, 09:12 PM
Guest
It looks like the second leaf there just slid laterally which puts the center of the second leafy further towards the back of the truck from the first leaf. Loosen the u bolts and maker sure the center pin which holds all your leads together didn't break and cause the leaf to "walk" I've had this happen many tines on my heavily lifted trucks that see a lot of trail time just do to constant fatigue and over flexing, as you could possibly see from not having the bump stops lowered with the 3in level kit ..... Just another thought and possible place to take a gander
xxxxxxxxxxxstrokincoal is offline
