Looking at a 2002 f-250 with the 7.3 - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-10-2014, 06:16 PM Thread Starter
New to this forum and have a couple questions. I know the 7.3 liter powerstroke was one of the better diesel engines that ford has made (in my opinion) and I'm going to look at a 2002 f250 with 130,000 miles on it this weekend at a dealership, there asking price is 16,900. I know a lot of you on here have a lot more experience and insight into powerstrokes and was hoping y'all could help. Is this a good price for the low miles? What things should I be looking for on a test drive/inspection of the truck?? Any help is greatly appreciated.
Thanks!
josdnunl is offline
post #2 of 12 Old 07-10-2014, 06:39 PM
hansel's Avatar
Quoted: 94 Post(s)
First thing is how does it run, how easy does it start up, does it take a few seconds or fire right. Then flip the oil cap over and see if the pressure blows it off if it does walk away. Check for any leaks on top of the motor and crawl underneath and look for leaks, this will be hard because the dealership will detail them making them look showroom good.
When test driving note how does it idle, how smooth does the transmission shift, is there any play in the steering, how do the brake's feel, etc....
Depending on the condition of the body and interior that might be a fair price but of course I'd start off below what they are asking, I'd start off a 15K but that's just me, I hate salesman and I have no problem telling them that, I'm not there to get screwed over or they can find someone else.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
The Following User Says Thank You to hansel For This Useful Post:
josdnunl (07-10-2014)
post #3 of 12 Old 07-10-2014, 06:57 PM Thread Starter
What does flipping the oil cap over do exactly? Test compression or what??
Thanks for the advice, I know a little bit about diesel engines but figured all of the guys on here would know a lot more.
josdnunl is offline
post #4 of 12 Old 07-10-2014, 07:06 PM
hansel's Avatar
Quoted: 94 Post(s)
Yes, you are testing for crankcase pressure, so if it blows the cap off means you have excessive crankcase pressure meaning weak rings or other damage.
I'm sure I've forgotten some stuff, but other's will chirp in
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
post #5 of 12 Old 07-10-2014, 07:12 PM
1997PSD's Avatar
Quoted: 2 Post(s)
16,900 is a little steep, I agree with hansel, try to get them down to at least the 15k range.
2000 F-250 XLT
Twisted Diesel Level II 4R100 w/ V10 Cooler
TS 6 Position w/ PHP Tunes.
4 inch turbo back straight pipe.
Wicked Wheel 2
18in XD's wrapped in 35in Toyo Open Country M/Ts
3 inch PMF shackles w/ Ford X-codes.
Re-routed CCV
Red Head Steering Gear
Isspro A-pillar Gauges.
7 inch pioneer touch screen.
'07 grille and Morimoto Retro'd headlights
'08 side mirrors.
Ranch Hand bumper.
1997PSD is offline
post #6 of 12 Old 07-10-2014, 07:18 PM Thread Starter
KBB says the truck is worth 14800, figured id start around there and see where it got me, thanks for the advice Hansel, Its been owned by the same person for the last 100,000 miles and not even 15000 miles a year was put on it. Im hoping that is a good sign, although i've heard that the worst thing for an engine is to let it sit....
josdnunl is offline
post #7 of 12 Old 07-11-2014, 07:30 AM
E-Man's Avatar
A good truck is always worth more than the average price. If it's been well cared for, properly maintained, and still looks great you're going to pay more than a comparable truck with the same mileage that has been ridden hard. Pull the Carfax, look for service records, and look at the undercarriage to see how it's been cared for. The undercarriage of a truck tells a lot about how it's been cared for over its life… Anyone can wash the body of a truck on a weekly basis, but a truck with a clean undercarriage shows that the truck has been well taken care of.
2001 F-250 CC SB 4x4 Off-Road w/ 88k miles on the 7.3. 4" lift on 35" BFGs. All synthetic fluids (Amsoil & Schaeffer's)
S&B intake, 4" turbo-back straight-pipe, 6.0 trans cooler, Dieselsite coolant filter w/ Delo ELC, Isspro gauges, Mag Hy-Tec diff cover
2012 tailgate, rear bumper, and tailights
2001 Excursion Limited
Only 55k miles on the 7.3
Bone stock
E-Man is offline
post #8 of 12 Old 07-11-2014, 07:34 AM
E-Man's Avatar
And You want to see the truck start cold. I flew up to Georgia to buy my truck, and I told the dealer on the phone to leave it in one place and not move it for several hours before I got there because I wanted to see it coldstart. When you get there Pop the hood and put your hand on the turbo to see if it is truly cold.
Bone stock
E-Man is offline
post #9 of 12 Old 07-11-2014, 09:34 AM
7.3LDriver's Avatar
Quoted: 5 Post(s)
Check for rust too if it is a northern truck. And if the truck is all stock then that i a plus. But if i is not and has a tuner/other mods then that might mean it was driven harder than usual.
Sounds like a great find! And welcome to the forum!
E99 F350 eclb drw 7.3L 4X4
220,000miles
leveling kit
35" tires
Donaldson Replacement 6637 Filter
Diamond eye 4" TB
ts6 with informant6 monitor
180/30 full force diesel injectors
d66 turbo
Riff Raff HPX and FRX
valair clutch
Zoodad Mod
Cam-locker toolbox
7.3LDriver is offline
post #10 of 12 Old 07-11-2014, 09:59 AM
over200's Avatar
Quoted: 5 Post(s)
I have a friend that has one I believe is $14,500 and is mint condition if interested ill put you in touch with him its located in Fl on the gulf coast.
2000 F350 CCLB 536 k+ miles still runs like a top!
Diablo chip, quickie pedal, valve body, Air Force One air intake, MBRP system, XD Diesels w/ MT ATZ's, KL5H Train Horns / Air Zenith supplied.
over200 is offline
