Drop track bar bracket or Adjustable bar? - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 27 Old 07-10-2014, 09:09 AM Thread Starter
Quoted: 3 Post(s)
So my truck came with a 4" tough country lift. The track bar bracket they supplied with it is a joke and needs to be replaced as you cannot tighten the bar (when I bought it the bolt was missing so I ordered a new bolt and cam).
Should I find a stock bracket and go with the Zone offroad adjustable bar or buy a 4" drop bracket with the OEM bar?
Thank you!
2001 F-350 4x4 7.3
2015 AXIS A24 surf boat
2012 Keystone Outback Travel trailer
r33pwrd is offline
post #2 of 27 Old 07-10-2014, 09:27 AM
ZMANN's Avatar
Quoted: 1566 Post(s)
what pitman arm do you run ?
We Miss you Ronnie
ZMANN is offline
post #3 of 27 Old 07-10-2014, 09:34 AM Thread Starter
Quoted: 3 Post(s)
I am going to assume the tough country one that comes with the 4" lift? I bought this truck with the lift already installed so I really don't know. Would a picture help you identify?
2001 F-350 4x4 7.3
r33pwrd is offline
post #4 of 27 Old 07-10-2014, 09:40 AM
sbluke55's Avatar
Quoted: 548 Post(s)
Garage
Best option would be take a picture of the front end showing all the steering components and post it up.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #5 of 27 Old 07-10-2014, 10:10 AM Thread Starter
Quoted: 3 Post(s)
here you go... looking at it I would assume that is the stock pitman arm? (Also I am assuming this is a 4" lift) Looks like my ball joint at the pitman arm is pretty nasty as well
I will say the front end of this truck reminds me of an old girlfriend... loose and sloppy but always got the job done
ID:	310081   Click image for larger version
ID:	310089   Click image for larger version
2001 F-350 4x4 7.3
r33pwrd is offline
post #6 of 27 Old 07-10-2014, 10:30 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Just make sure if you get a drop pitman arm, you get a drop trackbar mount as well...
Looking at your one from-the-front picture, your bars seem to be nicely in line. If you drop the pitman arm without dropping the trac bar you'll get bump steer, which is why so many people with these trucks run steering stablizers.
I have no stablizer with my steelies and 37's, I can take my hand off the wheel at any speed on a straight road, no bump steer.
Just something to consider, make sure you drop both.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
The Following User Says Thank You to schlutzer For This Useful Post:
r33pwrd (07-10-2014)
post #7 of 27 Old 07-10-2014, 10:43 AM
sbluke55's Avatar
Quoted: 548 Post(s)
Garage
That's the stock pitman arm. Looks like a torn boot in the joint at the pitman arm. If you find no play I would just replace the boot. Looks like it's the stock track bar as well. If you want to run a new track bar I suggest a stock track bar bracket and your choice adjustable track bar.
01 f-250, Standard
sbluke55 is offline
The Following User Says Thank You to sbluke55 For This Useful Post:
post #8 of 27 Old 07-10-2014, 10:49 AM Thread Starter
Quoted: 3 Post(s)
Thank you for the info. I am pretty sure I have a drop track bar mount already but its loose (uses a smaller than stock bolt) so is it okay to have a drop track bar and an oem pitman arm?
2001 F-350 4x4 7.3
r33pwrd is offline
post #9 of 27 Old 07-10-2014, 10:50 AM Thread Starter
Quoted: 3 Post(s)
okay that was what I was wondering... I just need to find a stock track bar mount I guess.
Thank you
2001 F-350 4x4 7.3
r33pwrd is offline
post #10 of 27 Old 07-10-2014, 10:56 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Its not okay for the track bar to be lower than the drag link no... Right now you are good in that aspect...
To me it looks like you need a 2-3" or so drop for both bars really.
I was just saying IF you drop one, you must drop the other as well
