zf6 to auto - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 21 Old 07-08-2014, 10:04 PM Thread Starter
Bigponcho's Avatar
zf6 to auto
Just as the title says, I want to get away from the stick, and go auto, I love my truck to death, so getting rid of it is not an option.
Does anyone know of a list, of things I will need. Swaps don't scare me, but it sure would be nice if someone else has already put together a shopping list.
Bigponcho is offline
post #2 of 21 Old 07-08-2014, 10:18 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Same thing as a manual swap but reverse...
At least thats what youll be told.
You need to swap the entire main body harness on the truck to go manual to auto.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
The Following User Says Thank You to schlutzer For This Useful Post:
Bigponcho (07-08-2014)
post #3 of 21 Old 07-08-2014, 10:20 PM Thread Starter
Bigponcho's Avatar
Has anyone done this before? Im sure I cant be the first
Thanks for the heads up on the harness. Im going to assume i need a radiator out of an auto aswell, or is the tranny cooler spererate on these trucks?
post #4 of 21 Old 07-08-2014, 10:27 PM
schlutzer's Avatar
Quoted: 18 Post(s)
These trucks have both a cooler in a rad and a stanalone
Yeah you probably are the first, nobody wants to do it because none of the transmission wiring is there.
Youl have to pull the dash, and since youll be that far in anyway you may as well pull the engine to make the harness swap easier.
post #5 of 21 Old 07-08-2014, 10:35 PM Thread Starter
Bigponcho's Avatar
Ive done a dash once, ohh jesus....
Im real damn sick of the zf6, sounds like it might be less work to toss an allison in it.
post #6 of 21 Old 07-09-2014, 09:07 AM
blue99stroker's Avatar
Quoted: 258 Post(s)
haha you wish.
you need harness, auto pcm or get your pcm re-flashed, transmission spacer between trans and engine. transfer case with a shorter input shaft, hell you might even need the whole steering column from an auto, but you'll definitely need to add the shift knob plus the linkage.
i think the manual swaps way easier
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #7 of 21 Old 07-09-2014, 04:16 PM Thread Starter
Bigponcho's Avatar
im looking at standlone controllers for the 4r100, might be the way I go, then this get a lot easier.
post #8 of 21 Old 07-09-2014, 04:51 PM
alaskan155's Avatar
Quoted: 60 Post(s)
before you do look at your driver side fender, there should be a few plugs , see if you have a populated one with extra pins/ a plug on the end of it, then all you need is the transmission harness.... worse case you are going to need the engine bay harness....
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
The Following User Says Thank You to alaskan155 For This Useful Post:
Bigponcho (07-09-2014)
post #9 of 21 Old 07-09-2014, 04:53 PM Thread Starter
Bigponcho's Avatar
I will go do that now! Thanks for the info
post #10 of 21 Old 07-09-2014, 04:59 PM Thread Starter
Bigponcho's Avatar
I have 3 plugs, all with wire going in them, they head under the truck towards the back of the rig. These ones you are talking about?
