Leaking Transmission fluid - Ford Powerstroke Diesel Forum
post #1 of 13 Old 01-21-2009, 12:05 PM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
Various 7.3 fluid leaks
So I pulled my truck inside the shop for the past 2 nights, and noticed both mornings some oil on the floor. I got under the truck, and right under the transmission (I have a manual transmission) there was some leaking oil. First off, I thought the transmission fluid was red, but this just looked like brownish motor oil. It was right around the drain plug, and I wiped it off and attempted to tighten it, but it was tight. There are a few bolts behind the drain plug and these were a little wet from the oil as well, but they also seemed tight. Any other ideas where this might be coming from? I'm going to pull my truck back in tonight and check the transmission fluid level.
2000 F350 Crew Cab Short Bed,
AIS Intake/Zoodad, 203 thermostat, Billet Housing
Vegistroke WVO conversion, AIH Delete, Wicked Wheel, TurboMaster Wastegate controller
Pyro/Boost/Tranny Guages
4" Magnaflow Straight Pipe
DP-Tuner F6 80hp Econo, 80hp Tow, Decel, 100hp Performance, 120hp Race
BioStroker is offline
post #2 of 13 Old 01-21-2009, 12:51 PM
sirnunya's Avatar
any oil on the engine side of things? could be leaking down the back/side of the engine onto the tranny.
sirnunya is offline
post #3 of 13 Old 01-21-2009, 12:54 PM
geoff thomas's Avatar
Send a message via MSN to geoff thomas
Check out powerstrokehelp.com there is a whole video section on leaks, thats how i found mine easy fix too!
2000 7.3 lariat
8" custom lift
24" Dub Hustla rims 37" toyos
Foil delete
Muffler delete with straight piped stainless side dump
geoff thomas is offline
post #4 of 13 Old 01-21-2009, 12:55 PM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
I didn't know about that-I'll check it out. Thanks!
post #5 of 13 Old 01-21-2009, 12:56 PM
its an awsome web site really helpful he covers everything
2000 7.3 lariat
8" custom lift
Foil delete
post #6 of 13 Old 01-21-2009, 01:07 PM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
Your truck must be a monster in the UK with all the small cars over there! Thanks for the input-I think I can use that website a lot!
Cheers!
post #7 of 13 Old 01-21-2009, 01:10 PM
yeah its pretty big can get hard to park but hey you gotta do i PSD are so sexy!!! it is a good site no worries
Geoff
2000 7.3 lariat
8" custom lift
Foil delete
post #8 of 13 Old 01-21-2009, 01:16 PM
CoalRollinRoosterCruiser's Avatar
Oh god, not again
Jonathon or John Although technically i have a list of nicknames the length of I-95, so call me what ya like
Current Truck--1999.5 F350 ext cab short bed SRW Lariat 4x4 ZF-6. 4" lift, 35's, exhaust, intake, chip, and more.
CoalRollinRoosterCruiser is offline
post #9 of 13 Old 01-21-2009, 01:18 PM
Powerstroke Junkie
NCHornet's Avatar
Careful that clown on the net has a lot of BS as well!!
First is to make sure what type of fluid it is. My bet it is engine oil draining down from the valley. Most common places are leaking O rings on the HPO lines, turbo pedestal O rings, and also the CCV will saturate the intake boots with oil, they will drip down into the valley and eventually down the back of the engine. If this is the source of your oil PM me and I will tell you how to keep the oil out of your intake.
NCH
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #10 of 13 Old 01-21-2009, 01:18 PM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
Originally Posted by CoalRollinRoosterCruiser View Post
Oh god, not again
What's up? Bad info on this site?
