fuel feed/return question ....... - Ford Powerstroke Diesel Forum
post #1 of 17 Old 07-08-2014, 09:24 AM Thread Starter
Guest
I've been researching and looking at all the diff fuel set ups and kits you can buy. I've seen one where a guy just ran a tube from one cylinder head in the rear to the other cylinder head across in the rear( driver to pass ) and I assume feeding both heads at the front? Is there any gain or harm in this also this made me think ..... What would happen if you were to "T" out of each feed line from the bowl and fed all 4 corners of the fuel rail? Any harm or gain from this ? I am a doer, fabricator and like building things myself so I've been looking at all the ways to better my fuel system without just buying some expensive overpriced kit. Which believe me I buy the overpriced stuff all the time and would expect the same value for my work as well. Just a couple ideas that poped into my head that I haven't seen in any of my research. Ive built many 1000hp+ race cars and boats but am new to the diesel world as far as performance. Hopefully a few of you intelligent guru's will help me a little
xxxxxxxxxxxstrokincoal is offline
post #2 of 17 Old 07-08-2014, 09:44 AM
sbluke55's Avatar
Quoted: 624 Post(s)
Garage
What size injectors do you plan on running? If you plan on mild injectors a FRX is all you need or a diy regulated return. When you get into the bigger injectors you need a full fuel system. Like a sump, 1/2" lines to the heads and a full regulated return. So once you figure out your size of injectors you can figure out your fuel system. What I'm going to do is a diy regulated return because I can get most the parts free besides the regulator. Fuel bowl delete and hutch mod. I believe that should keep a good flow of fuel to my injectors. I'm waiting to get injectors tell my system is complete. I'm only going to run 160/30 but having $400 into a fuel system to protect your $1500 injectors is a good insurance to me.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #3 of 17 Old 07-08-2014, 10:09 AM Thread Starter
Guest
I deff agree on insurance for exspensive parts. I think I'm just goin to do some hybrids 200s or so and a 38r later but the fuel thing is just curiosity as I already know what I plan to do. Just was curious as to how or what the function of these two "ideas" were . It would be quite simple to feed all 4 corners easier than it would be to do a frx or regulated return or even the bowl delete. Or the idea of just feeding both heads at the front and tiring the together in the rear to complete the circle flow of fuel?
post #4 of 17 Old 07-08-2014, 10:58 AM
sbluke55's Avatar
Quoted: 624 Post(s)
Garage
By feeding all 4 corners or looping the rear together you will still force air threw the injectors. Using the regulated return or FRX you allow the air to exit back to the tank and not go threw the injectors. Air and injectors don't go well together. In a perfect world there would be no air but there is little bubbles trapped in the diesel and small air leaks pre pump.
01 f-250, Standard
post #5 of 17 Old 07-08-2014, 11:33 AM
Quoted: 901 Post(s)
Feedback Score: 3 reviews
You are NOT going to force any air into the heads. A RR return does not remove any "so called" more air than any other syste. That whole idea is just a wild guess that has never actually been proven. IF there is ever any air in a system, it will quickly go to the highest point and then get pushed back through to the tank regardless if its a RR, factory setup up, 4 line feed.
To get one thing straight before people pop off info that they have no factual data to back up, a traditional RR is still a good product. In absolute no way am I bad mouthing it. It is proven to work, but it still has its limitations.
Corey@CNCFAB is offline
post #6 of 17 Old 07-08-2014, 11:51 AM
sbluke55's Avatar
Quoted: 624 Post(s)
Garage
Ok. So I got some bad info. I know a regulated return keeps a constant pressure to all injectors by regulating pressure after the injectors. Question to you is what makes the FRX beneficial to you fuel system? From what I've read it has small ports allowing fuel to return to the regulator while still using the factory pre injector regulator. Correct me if I'm wrong on how it works. So if there is no air in the system why use it? I know a regulated return you have constant pressure to all injectors but the FRX would still be able to starve the end injectors correct?
01 f-250, Standard
post #7 of 17 Old 07-08-2014, 12:15 PM
Quoted: 901 Post(s)
A RR or even a factory setup still maintains a set pressure.
I don't use the FRx hose. I personally hate to hose anything as it looks messy, but sometimes you have no choice. And the price csn dictate that.
What the RR and FRx does is just moves the pressure relief (regulator) to a different spot in the circuit. Instead of right at the bowl on a factory system it can't bleed off as soon as it entered the bowl. So it forces the fuel into a different route. That's how it helps to not let the opposite end injectors starve. A RR does a better/cleaner look to move the pressure relief further back in the circuit than the FRx.
Here's the biggest drawback of the factory setup. The factory fittings in the heads have a tiny ball-check in them plus a screen mesh. These dumb things dramatically reduce flow and cause air in the system. (Just like that screen on your kitchen faucet).
On a RR, a 3/8" line is used to feed the back of the heads. Which is fine in itself, but also pointless because the port in the back is still only 1/8" pipe fitting (still somewhat restricted). You can only push X amount of fuel at X amount of pressure through such a small hole. A four line feed will balance the pressure throughout the heads regardless and give you double the possible flow over a RR if needed. In our race truck, its needed.
FYI, I do have a significant amount of run time on both systems I make with different HP setups too.
post #8 of 17 Old 07-08-2014, 12:16 PM Thread Starter
Guest
That's what my brain was telling me while looking over all these designs. Laws of physics are laws of physics and are rarely deviated from. What do you recommend as a mild upgrade to Ford's factory fuel system? I would like to smooth out all the little stuff before I go to bigger injectors and turbo.
The Following User Says Thank You to xxxxxxxxxxxstrokincoal For This Useful Post:
Corey@CNCFAB (07-08-2014)
post #9 of 17 Old 07-08-2014, 12:26 PM Thread Starter
Guest
Do you think just running feed lines to the open ports on the heads would be overkill or helpful in a rather low/stock motor? Or with the feed holes and lines being so small not allow too much fuel to flow ? I just think that feeding both sides of the rail would alleviate any injector from ever starving. Also how beneficial is it to remove those check-balls and screen fittings as an upgrade in itself?
post #10 of 17 Old 07-08-2014, 01:02 PM
Quoted: 901 Post(s)
The FRx will work. Some have said they've had minor issues. But I dong like hoses.
The fuel bowl 4 line feed will be plenty for you. My truck and another have been running this kit for a year now and were both at high 500 to low 600hp range. I also am using the OEM billet regulator from Bob at dieselorings. Its not necessary, but the ford ones have a tendency to crack. The line kit is $250 shipped to your door.
