4r100/e4od vs zf5/zf6 - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-07-2014, 06:26 PM Thread Starter
Conner"mac"Henry's Avatar
What are the weeknesses and stregths of them? Im curious because im looking at buying a 7.3 and i know what to look for but im having trouble making my mind up on which one to get i plan on doing some towing and the truck will be my daliy driver too so ill have to rely on it....
Conner"mac"Henry is offline
post #2 of 10 Old 07-07-2014, 07:26 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Do you want bigger power? How heavy do you tow?
E4od/zf5 is obs, 4r100/zf6 is SD, which body style do you want? Of planning to add a bunch of power the auto's WILL need beefing up to hold, the hand shakers will need clutches upgraded, do you like shifting or holding your big gulp more?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 10 Old 07-08-2014, 07:06 AM Thread Starter
I like shifting and ill be towing a 65 falcon drag car to the races and eventually id like to have around 400 hp in the 7.3 the body style probly a super duty
post #4 of 10 Old 07-08-2014, 02:47 PM
BrodieBiking's Avatar
A zf6 is stronger out of the box then a 4r100.
Personally, I love my zf6 and don't see myself changing back to auto.
But as he said, if your looking to get around 400hp definitely upgrade the clutch.
Sent from AutoGuide.com App
2002 F350 CCLB DRW
ZF6 SWAPPED!
--Southbend 1944-6OFEK
12.5in lift on 24.5's----------3" Body Lift
MBRP Dual 4"--------------Muffler Delete
K&N Intake----------------AFE Spider
Garret GTP38R BB--------- P.I.S. billet wheel
TS 6pos chip--------------NLTD tunes
P.I.S. 200cc/80%--------- P.I.S. IDM
Parrot Asteroid-------Boston Accoustic SR80's
NVX VCW 10s------------ McIntosh MC431
Warn Manual hubs---------Bed Rails/Air tank
BrodieBiking is offline
post #5 of 10 Old 07-08-2014, 05:03 PM Thread Starter
I looked at a 2000 250 with a zf6 it drives nice but the clutch is fussy going into reverse what could be wrong ever other gear is fine....
post #6 of 10 Old 07-08-2014, 05:52 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Synchros probably, one thing to keep in mind is how much shifting you want to do, if at all, the stick is much better suited for towing IMHO, but I have kids and ride alone with them often, so I'm not fiddling with it much, that and I like eating my burrito while steering with my knees and not shifting
If I only towed with it I'd do a stick tho, but it's my DD too
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 10 Old 07-08-2014, 06:07 PM
How many km on the truck?
2002 F350 CCLB DRW
ZF6 SWAPPED!
post #8 of 10 Old 07-08-2014, 10:54 PM
Austen's Avatar
Quoted: 31 Post(s)
Have you driven a HD truck before with a manual? If not, you will want to make sure it's something that you will not mind. Test drive some of these manual trucks, if you can find some.
If the auto is not already been built, that is something to consider as it will most likely in the future need to be especially if you start adding power. Upgrading the trans in a diesel truck is just part of the name of the game. It is a several thousand dollar expense.
To put a stronger clutch in a manual is considerably less than rebuilding an auto.
Driving a manual, especially in a HD truck, takes the right person. It is not for everybody, that is for sure. The manual is for a true vehicle enthusiast who appreciates having the involved experience of having as much control over your driving experience as possible. If this is you, then it may be up your alley. If you do not care so much about that sort of thing, then honestly, you probably will not like it at all.
You'll find the small majority of folks that drive a manual diehard enthusiasts that wouldn't have it any other way and the ones that don't claim they would never in a million years step close to a handshaker.
You'll know which side of the fence you fall on pretty quick once you drive one.
08/98 CCSB l 7.3 l ZF6 l TW tuned l 38R turbo l Deleted EBPV l Bellowed up-pipes l FRX l HPX l OCR l Isspro gauges l 99.5 PCM l 6637 w/ K&N intake duct l 4" MBRB straight pipe w/ axle dump l 6" suspension lift l 37" Toyo MTs l 17" KMC Strike rims l ARB front bumper l HNC rear bumper l bedliner'd rockers l Bushwacker flares l custom cab guard l '08 tailgate l PIAA fog lights l Recon tail lights l B&W hitch l air shocks l Pioneer stereo
Austen is offline
post #9 of 10 Old 07-09-2014, 01:05 AM
Bigponcho's Avatar
test drive, test drive, then test drive some more. I have a zf6 truck. For what i do, its pain in the ***. I wish I would have gotten an auto. I know once i start hualing around a race car i might like it better, but honestly, at this point im thinking about selling it off, or sucking it up and trying to swap an auto in.
Bigponcho is offline
post #10 of 10 Old 07-09-2014, 03:20 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I cannot totally agree here, my trucks are auto, my cars are stick, it's a slightly higher expense, but unless I'm loaded and headin for hills I have no issue being auto
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
