Need help I can not figure this out! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-07-2014, 02:41 PM Thread Starter
Alright y'all so I have an 03' Ford F250 super duty with the 7.3L turbo in it. A few weeks ago I was hauling cattle to the sale barn and made it there no problem. (65 miles) on my way out if the driveway went to get up to speed and she just wouldn't go past 40 mph. Started a quick ticking noise sounds like it was coming from the driver side just beyond the firewall. Then it started shuddering and spitting like I lost a cylinder or 2. Had it towed to the dealer spent 2500 bucks and didn't fix ****. They replaced the icp and 2 injectors and the wiring harness under the valve cover. I was able to make it home with the truck and we've had it since been trying to fix it and use it at the same time. Well now it's getting more frequent and it's really annoying. Sometimes I can drive it 200 miles without one issue. Other times I can drive it 20 miles and it'll loose power and just die on me. I'm outta ideas and need help. I've checked every fuse and every relay. They all function as they should. Oh and right before I start to lose power and it throws on the check engine light. But no codes. At least that I can pull with the scan tool we have. (Cheapy one) trip meter gives me codes of 9352,9201,d059. I'm at a loss on this one because I don't normally deal with electrical stuff. I was more a brakes steering and suspension tech. Not so much electrical diagnosis. Also I've got the tank out now because I thought I had a bad sending unit (fuel gauge isn't working) guys any questions you may have ask me. This things driving me up the wall and I don't know what else to do.
Jayjay9002 is offline
post #2 of 7 Old 07-07-2014, 03:09 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 370 Post(s)
First i'd check fuel pressure. Have you ever changed the cps? (Cam Position Sensor). Its around 20$ at ford.
Then if all that checks out I'd be thinking IDM. (Injector Drive Module) its in the driver side fender well behind the plastic guard near the cab. When you take plastic piece loose pull it out the. Look up and the the right. You'll see the 10mm bolt for the plug.
Good Luck
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
The Following User Says Thank You to LoxDiesel For This Useful Post:
Jayjay9002 (07-08-2014)
post #3 of 7 Old 07-07-2014, 06:15 PM Thread Starter
Yes already replaced the CPS. IDM is on it's way should be here tomorrow. If that doesn't fix it what should I look at next? I'm out of ideas.
post #4 of 7 Old 07-07-2014, 07:11 PM
LoxDiesel's Avatar
Quoted: 370 Post(s)
I'd test fuel pressure next for sure.
@loxdce
post #5 of 7 Old 07-07-2014, 10:33 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
ouch they charged you 2500 for 500 bucks worth of parts and like 3 hours labor wtf
did you ever check the ipr and see if the tin nut fell off or the firing is chafed.
also check the main wire harness were it goes over the valve cover, it can chafe through and cause issues as well.
running any sort of chip/or tuning?
and get a better reader that actually pulls codes. the codes might tell you whats wrong but you don't know if you can read them
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
The Following User Says Thank You to blue99stroker For This Useful Post:
post #6 of 7 Old 07-08-2014, 08:33 AM Thread Starter
No chip no tuner this is just the farm beater. Although it needs to run because it's cheaper to run this than the other truck. I have not checked the ipr but the shop said they checked the wiring and all that. Although now in not so sure how much I believe them. The IDM should be here today so I'll put that in and let y'all know once I get the tank back up.
post #7 of 7 Old 07-09-2014, 01:54 PM Thread Starter
Alright y'all IDM just got put in made it 10 miles and she's doing the same thing although this time no check engine light. I don't have a fuel pressure gauge at the moment but I'm sure I can get one. I'm lost as to what to do.
