Brakes - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-07-2014, 10:07 AM Thread Starter
Brakes
I have a 2001 7.3. When I apply the brakes very quickly they work until i slow down to about 10 MPH then the pedal goes down to the floor or if i reapply the brakes. If I apply the brakes slowly at any speed the pedal goes down to the floor. Any solutions or recommendations?
mjm2001 is offline
post #2 of 6 Old 07-07-2014, 10:18 AM
1997PSD's Avatar
Quoted: 2 Post(s)
Have you looked around for a fluid leak?
2000 F-250 XLT
Twisted Diesel Level II 4R100 w/ V10 Cooler
TS 6 Position w/ PHP Tunes.
4 inch turbo back straight pipe.
Wicked Wheel 2
18in XD's wrapped in 35in Toyo Open Country M/Ts
3 inch PMF shackles w/ Ford X-codes.
Re-routed CCV
Red Head Steering Gear
Isspro A-pillar Gauges.
7 inch pioneer touch screen.
'07 grille and Morimoto Retro'd headlights
'08 side mirrors.
Ranch Hand bumper.
1997PSD is offline
post #3 of 6 Old 07-07-2014, 10:28 AM
sbluke55's Avatar
Quoted: 550 Post(s)
Garage
I would check all your caliper slide pins are greased and moving, pads and calipers. If you find any leaks repair them. Do a good bleed on your brakes and see how it does after that.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #4 of 6 Old 07-07-2014, 10:30 AM Thread Starter
No Leaks, reservoir is full. Bled the lines to make sure there was no air. Power steering is working
mjm2001 is offline
post #5 of 6 Old 07-07-2014, 10:34 AM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
seals internally in master cyl are getting worn....time to replace master cyl.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is online now
post #6 of 6 Old 07-07-2014, 11:15 AM
sbluke55's Avatar
Quoted: 550 Post(s)
Garage
Brakes
Yep master cylinder time. Make sure to bench bleed your master cylinder or you will have a hell of a time getting a good pedal
01 f-250, Standard
