What doorman products should I stay away from ? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-06-2014, 07:51 PM Thread Starter
I looking at replacing a few parts here and there on my truck and I am looking at OEM and realizing I may need a second job so I am looking for your guys experience and help to figure out what parts I must use OEM and what parts I can use doorman or other after market parts. My truck is not used as a daily drive and is used mostly as a weekend warrior pulling a boat around the Pacific Northwest lakes.
I have asked the ford dealer sponsor on here for a few parts but would also like to try and save a few bucks where I can so I can buy a few toys for the truck later like a chip and billett wheel.
Thanks for any and all help.
Chevydog is offline
post #2 of 9 Old 07-06-2014, 07:55 PM
sbluke55's Avatar
Quoted: 553 Post(s)
Garage
What parts do you need.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 9 Old 07-07-2014, 12:25 PM Thread Starter
I was looking at the up pipes, valve cover gaskets and possibly exhaust manifolds.
Thanks
Chevydog is offline
post #4 of 9 Old 07-07-2014, 12:50 PM
sbluke55's Avatar
Quoted: 553 Post(s)
Garage
Up pipes are ok from Dorman. Gaskets you should get from sunrise. Exhaust manifolds eBay. Why do you need manifolds.
01 f-250, Standard
sbluke55 is offline
post #5 of 9 Old 07-07-2014, 12:53 PM
ZMANN's Avatar
Quoted: 1589 Post(s)
I used to buy their stuff but then the oil cooler issue /gasket problems / WTF happened ? I even heard of problems with their packaged bolts
seems like everything they dabble in is a potential problem
We Miss you Ronnie
ZMANN is offline
post #6 of 9 Old 07-07-2014, 02:16 PM
Quoted: 27 Post(s)
I can get Ford OEM parts at cost and i Live in Monroe, Work in Issaquah. Let me know if you want a price check.
Sensors and what not, go OEM. Up-pipes I prefer International cause the name is cool. No idea if other brands are less quality but International is proven and mine work well and instillation was easy.
Valve cover gaskets, Riffraff has good deals.
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #7 of 9 Old 07-07-2014, 03:32 PM Thread Starter
My manifolds look pretty rusted and I thought I would just look into new ones because I am going to install new up pipes soon.
I would like to go international but the price is a little (ok a lot)out of my budget I just want to keep the truck going as it has 418000 miles so I want to try and save my money for the big items like tranny and possible rebuild. So if I can get some good deals and or use aftermarket parts here and there then I will.
Thanks again for all the info guys.
Chevydog is offline
post #8 of 9 Old 07-07-2014, 06:31 PM
sbluke55's Avatar
Quoted: 553 Post(s)
Garage
I'd sell you my obs manifolds but they won't fit. eBay should have the best buy. There is no need to buy new. If they are not rusted to bad just sand blast them and then use header paint
01 f-250, Standard
sbluke55 is offline
post #9 of 9 Old 07-07-2014, 10:39 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
if they don't leak i wouldn't both pulling them. clean them and paint if you want
dormant up pipes seem to be better quality now. only 170 from rock auto.
the valve cover gaskets only need replacement if the leak (very rare) or the uvch shorts and melts the gasket, otherwise don't bother replacing the gaskets.
the uvch can be had from dieselorings for only 40 a piece oem parts too!
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
