ICP sensor plug full of oil ? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-06-2014, 06:29 PM Thread Starter
I was looking around for all my oil leaks today and noticed the plug on my ICP sensor was wet so I pulled it off to look and it was filled with oil both in the plug and the top of the sensor. So do I need to change it or is it ok like this or ?
I have read that it needs to be changed and some guys say just remove it and plug the hole and the module will reset to factory default so I am not sure what to do here.
Thanks for any and all help.
Chevydog is offline
post #2 of 7 Old 07-06-2014, 06:39 PM
AnthonyU's Avatar
Quoted: 6 Post(s)
The proper thing to do is change it
AnthonyU is offline
post #3 of 7 Old 07-06-2014, 06:52 PM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
Replace the icp and pig tail with oem parts. When connecting the pigtail to the harness solder all connections then use heat shrink. Butt connectors are junk and lead to corrosion and high resistance. Search sunrise ford here and you can get discounted parts.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #4 of 7 Old 07-06-2014, 07:13 PM Thread Starter
Thanks guys looks like I have another thing to add to my list.
Chevydog is offline
post #5 of 7 Old 07-06-2014, 08:41 PM
blue99stroker's Avatar
Quoted: 243 Post(s)
just clean the connector out with electrical cleaner, then get a new icp.
most don't need to replace the connector.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #6 of 7 Old 07-07-2014, 05:59 AM
Quoted: 132 Post(s)
Feedback Score: 3 reviews
Yea, I don't know where all the "Replace the ICP connector" is coming from but, No! (unless the insulation is failing and while that can be an issue with the IPR connector, the ICP is in a different place and it's wires don't often do that).
BUT, for OIL??? - Certainly not... Oil is Not A Problem in an electrical connection.
NoRalPh is offline
post #7 of 7 Old 07-07-2014, 06:55 AM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
Ok. I've been corrected. Thanks
01 f-250, Standard
