Help turbo bad - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-06-2014, 09:35 AM Thread Starter
Help turbo bad
I am replacing a turbo on a local persons truck. I ordered it Tuesday. But today is Sunday. Turbo is supposed to be here tomorrow. I tried putting there old one back on. I took it apart. It's worn, but to my knowledge the turbine wheel was hot hitting housing and scraping. It is now. They are demanding the truck back today to use it for work tomorrow. Right now this turbo is not usable. I don't know what to do. I just dove it and I hear scraping noise from it under acceleration. Any ideas?
2008 6.4 f250 lariat 4wd
melmount is offline
post #2 of 3 Old 07-06-2014, 10:07 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Hit up craigslist to find another, or find a pull a part that's open
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 3 Old 07-06-2014, 03:14 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
can you get a rebuild kit from a stealership early tomorrow?
doesn't take long to rebuild.
also make sure you didn't tighten the pedestal down too tight!
it will cut of oil flow and do exactly what you described.
i know from experience
i think it only needs 10-15 ft lbs.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
