I need some AC Help please - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-06-2014, 07:52 AM Thread Starter
My 2k 7.3 ac works great except every now and then when I run the fan wide open it quits cooling and then later starts cooling again. Any ideas what is causing this? Getting ready to make a long run to Islamorada Fla. pulling a boat, so I really need to get this fixed.
I am not a mechanic but mechanically inclined with lots of tools.
Thanks in advance.
cokerta is offline
post #2 of 13 Old 07-06-2014, 08:18 AM
My 2000 does this occasionally as well. Usually I think it is just my imagination or I am just really hot and it seems to be underperforming but then later it freezes me out of the cab. I am following this as well to see what people say.
I do know that I have read about the clutch shims needing to be removed as the electromagnets that draw the compressor clutch become weak over time and cannot pull the clutch into the compressor unless the gap is minimized. I haven't had a repeated enough problem to necessitate taking the clutch off the compressor and removing shims. Search the forum for clutch shims, ac compressor ect...
2000 F350 Crew Cab 7.3 liter 4x4 short bed, 6 pos w/PHP, 6637 filter, hutch, harpoon, 4" downpipe, 5" exhaust, ISSPRO gages, 305 series tires, stock suspension with level kit up front, '05 headlight mod.
2001 F250 ECSB 4x4 - sold
2001 F250 CCSB 2WD -sold
2002 F250 ECSB 4x4 lifted -sold
Mama's 2009 Expedition EL 4x4
Last edited by biscayne; 07-06-2014 at 08:24 AM. Reason: added info as an afterthought.
biscayne is offline
post #3 of 13 Old 07-06-2014, 08:23 AM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 330 Post(s)
Probably just low on freon. You can get those cans with a gauge at most auto parts stores for the low side and charge it up according to outside temp. It probably won't need much.
After that you should be good to go!
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #4 of 13 Old 07-06-2014, 08:29 AM
Slacker
Evil Eye's Avatar
Quoted: 191 Post(s)
Feedback Score: 4 reviews
Either it's a tad too full of freon (R134a) or your air gap on your compressor could be out of spec.
If it's too full, it will cause an over-pressurization condition (on the high side) and will cause your compressor to unlock. Get a set of AC gauges to check both high side and low side pressures.
If your air gap is out of spec, the clutch won't be able to engage, particularly when it gets hot outside and your clutch and compressor get hot.
Finally, ensure that your cooling fan is performing properly (which is what my situation ended up being). It may seem kind of strange, but it should lock up partially in order to pull air across the condenser and maintain your cold air conditioning.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #5 of 13 Old 07-06-2014, 08:31 AM
Slacker
Evil Eye's Avatar
Quoted: 191 Post(s)
Based on freezing cold at some times and then not working at other times, it is unlikely too low. You HAVE to measure both high side and low side pressures. Those cheapy throw away AC cans ONLY measure low side, so it's very easy to over-pressurize the system.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #6 of 13 Old 07-06-2014, 10:11 AM
LoxDiesel's Avatar
Quoted: 330 Post(s)
If you over pressurize then the low side will also be too high. Pressure of freon isn't only based on the amount in the system. It is also based on temperature of the freon itself. So if your fan clutch isn't working your pressures will rise. If your orifice is clogged your high side will be too high and low side will be low. Even if it does over pressurize it will kick the compressor out and you'll need to tear into the system anyway.
The reason I recommended the charge can was if he had to be "Ballin' on a Budget" was all.
@loxdce
post #7 of 13 Old 07-06-2014, 11:06 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Mine the clutch won't engage sometimes so I hop out tap it in, and it gets good and cold but eventually pops back out, so I repeat the process, I've never messed with an a/c system so not really sure what to do about it other then go to a shop, but I hate paying for mechanic work that I should be able to perform in my driveway
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #8 of 13 Old 07-06-2014, 01:16 PM
Slacker
Evil Eye's Avatar
Quoted: 191 Post(s)
You mentioned a clogged orifice tube and also air in the system can cause the same issue. Just throwing another can in the system can lead to a VERY bad day... The Harbor Freight gauges are $50, they are the correct tool for the job and can prevent hours of frustration. It's better than just throwing a $30 can of freon at the problem and hoping that you get lucky.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #9 of 13 Old 07-06-2014, 02:43 PM
Quoted: 13 Post(s)
When it stops working tap on the front of the A/C clutch and see if it starts cooling again. Mine is doing this. Could be time to remove shims or new clutch.
Dave
02 F350 CCLB Lariat 4x4 auto
230,000 on the clock
dieselsite trans filter,
dieselsite coolant filter,
6637 filter
Stancor GPR
6.0 tranny cooler
4" Diamond Eye K4318S-RP exhaust
riffraff regulated return
dual alt.style upper rad. hose
05-07 head light mod
PHP Hydra
Alliant Power 160 single shots
WW2
HPOP system cross over hose from Corey
3 gauge A pillar gauge pod with EGT, trans temp and boost gauges. Autometer ford matched gauges.
glow plug light installed in gauge pod.
welove2drive is offline
post #10 of 13 Old 07-06-2014, 08:57 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
That's exactly what mine does, when I tap it starts spinning again
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
