Injectors! - Ford Powerstroke Diesel Forum
post #1 of 23 Old 07-05-2014, 05:16 PM Thread Starter
Injectors!
Hey guys, I am rebuilding my injectors soon, i think I'm going to do the 75 horsepower nozzles. Do I need a tune to run those? And will the stock fuel pump keep up? I believe I can go 40 and 50 hp also. Also if anyone has done this what programmer would you recommend pairing the upgraded injectors with?
tjduke is offline
post #2 of 23 Old 07-05-2014, 06:09 PM
heykw's Avatar
Post a link to what it is your talking about.
Most injectors are not sold by HP rating
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #3 of 23 Old 07-05-2014, 06:13 PM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
Injectors are not rated at hp increases for our trucks. They are rated buy size, ie 160/30 or 175/80. They are also rated at a generic stage 1 and stage 2 ratings. What do you want to do with your truck? Do you tow? What's your goal hp rating? What's your budget?
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #4 of 23 Old 07-05-2014, 10:02 PM
blue99stroker's Avatar
Quoted: 244 Post(s)
yikes, we better help this poor fellow before csipsd gets ahold him of him
HEUI injectors are very different than most injectors. there is a lot of internal parts that need to be modified and then flow checked to make sure they are all similar. otherwise you can never have someone tune the truck right.
like sbluke said, we have different size nozzles, 30% 80% and higher
the 75hp injector thing is a cumminGs thing
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is online now
post #5 of 23 Old 07-05-2014, 10:43 PM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
I know. I remember that last time this came up.
01 f-250, Standard
post #6 of 23 Old 07-06-2014, 04:33 AM
Solid98's Avatar
Quoted: 8 Post(s)
Party pooper.
He's probably in the shop modifying some more Stage 2 intake spiders.
01 F250 XL Ex Cab: RIP 12-15-2013
1999 F250 XLT 4X4 auto, Bully Dog 5" straight pipe, rest stock.
Solid98 is offline
post #7 of 23 Old 07-06-2014, 05:45 AM
Quoted: 5 Post(s)
I just put some 7.3 injectors in my 6.0 powerstroke, now it runs just like my 7.3, I think I like it now!!??
2002 f250 ccsb 4x4, 250/200's,5 inch mbrp,itp boost fooler,regulated return/race fuel system, s&b intake, billet 4r100, swamps idm, lifted 2 inches, leveled, 35inch nittos on 18" s468, mishimoto intercooler, hydra tuning, detroit locker rear, dynomat, not done.........
2006 f350 ccsb 6.0, sct tuner 3015 custom tunes, studded, deleted, exhaust
mastertech79 is offline
post #8 of 23 Old 07-06-2014, 04:35 PM Thread Starter
I use the truck for work. I tow a lot. Right now the truck is stock. My main goal is good fuel mileage out of a tow rig. But if it's fast to then I'm all for it. I found a site that sells a kit to rebuild and modify the injectors to flow more and they have the horsepower ratings for each stage
tjduke is offline
post #9 of 23 Old 07-06-2014, 05:15 PM
Joel's Avatar
Quoted: 10 Post(s)
Listen closely, do not buy a DIY kit, and do not buy from whatever site that was.
The injectors used in these trucks are a lot more involved than cummins injectors.
Swamps, Power-Struck, PIS, rosewood, and full force are the big guys that come to mind.
For your application I would suggest a 160/0 or 160/30 from any of the above builders.
With proper mods that will get you 350 to 380 horsepower or so
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #10 of 23 Old 07-06-2014, 05:34 PM Thread Starter
Okay so say I get my injectors built by one of these companies, do I have to run a custom tune or can I use a can tune or a six position chip. Are the injectors even worth doing? as of right now my injectors have to come out and be cleaned up
tjduke is offline
