Drain On Fuel Filter - Ford Powerstroke Diesel Forum
Old 12-21-2006, 05:50 PM
Has anybody ever had porblems with the drain on the fuel filter that sits right on top the motor leaking. Mine is and i would really like to fix it rather than let my $2.59 diesel run out on the ground.
Old 12-21-2006, 05:52 PM
Jon
Guest
Posts: n/a
I change
about 5 a week.
Old 12-21-2006, 06:03 PM
How to
Any tips on how to do it or how hard it is. id really like to fix mine.
Old 12-21-2006, 09:06 PM
Here is a wep site to walk you fix the leak. Its real easy to do. I got my new o-rings at Mcmaster carr for $6.00 for a bag of 25 just because its cheap and they are Viton and they hold up better in fuel but you can go and get some at a hardware store if you want a quick fix but they may not be Viton and you will pay more for them and they might not last as long. If you do the size is 1/8 x 1/4 x 1/2.
Good luck
Brian
Old 12-21-2006, 09:10 PM
Good luck
Brian
opps, sorry about the bad typing above. I guess I should read what I type before I click submit.
I ment to say Here is a web site walk thru to help you fix the leak.
