Trouble installing radio in a 2000 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-04-2014, 03:40 PM Thread Starter
I had a Crutchfield harness that does not match up so I started to hard wire the radio in. Everywhere I check on the internet they say the constant power wire is a light green wire with a pink trace. My truck does not have any pink anything. So far I was able to find a switched power that is a black wire with a purple trace.
I have the following color wires
Green with orange trace
white with green trace
blue with red trace
grey with blue trace
orange with green trace
solid black
2 wires that are black with a purple trace (one of which I believe is the switched source that lit up my test light with the key on)
tan with yellow trace
2 black with green trace
blue with white trace
green with black trace
Does anyone know which wire is which? Thanks
Ward1 is offline
post #2 of 7 Old 07-04-2014, 04:04 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Which one is hot with key off?
Wal mart has the harness for like $8
Sorry I don't have a diagram on me here
Excursion one off google search
Stereo wiring harness colors - Ford Truck Enthusiasts Forums
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 7 Old 07-04-2014, 04:15 PM Thread Starter
None of them are hot with the key off. Maybe a fuse is blown? Do you know where that fuse is?
Ward1 is offline
post #4 of 7 Old 07-04-2014, 04:47 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Under the steering column should be the radio fuse, there should be a constant (for clock and memory functions) did you already cut the factory harness?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 7 Old 07-04-2014, 05:35 PM Thread Starter
Yes I already cut it.
Ward1 is offline
post #6 of 7 Old 07-04-2014, 09:24 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Then the fuse is already blown most likely already
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 7 Old 07-05-2014, 01:11 PM Thread Starter
You were right, I replaced the fuse and I found the constant right away. It was a green wire with a black trace
Ward1 is offline
