UP PIPE GASKETS - Ford Powerstroke Diesel Forum
Old 01-19-2009, 06:16 PM
UP PIPE GASKETS
I am looking to relace my up pipe gaskets with chevy 350 doughnut gaskets. I was wondering is there just the two gaskets at the top of the up pipes or is there also two at the bottom of the up pipes where they connct to the manifolds? Do I need two or four of the doughnut gaskets. Thanks for the info.
Old 01-19-2009, 06:19 PM
Jon
Guest
Posts: n/a
2, only at the top.
Old 01-19-2009, 06:36 PM
Lifetime Premium Member
only two at the top..I used the sbc ones and couldnt get them to collapse.I will be ordering the bellowed up-pipe kit.
Old 01-19-2009, 07:07 PM
I just put on the bellowed kit without taking the turbo off. It wasnt to bad but i dont think i have the band clamp on the inlet completely tight yet. Sounds like it is leaking a little.
Old 01-20-2009, 02:18 PM
Which donuts did you use? The OEM or Chevy 350?? Just curious...
Old 01-20-2009, 02:22 PM
hey can somebody shoot me the link for the bellow up pipe kit i am in the process of fixing mine and that would be great????
Old 01-20-2009, 07:08 PM
The bellowed Up-pipes do away with the whole problem with the donuts.
It uses flat metal gaskets
http://www.dieselsite.com
They are a site sponser
Old 01-20-2009, 11:17 PM
the ford oem ones are like $17 a piece. the chevy ones are 1.99.
Old 01-21-2009, 06:02 AM
hey thank you sir
Old 01-21-2009, 06:04 AM
I just replaced mine with the Chevy 350 donuts (Carquest #F17250). These are crushable and form a good seal over the stockers.
