I want to see if my truck is running like it should what do I need and what's it cost - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-03-2014, 10:09 PM Thread Starter
I have been reading all I can for the last few weeks and have come to the conclusion that before I start to try and get more power or performance I need to know if my truck is running the way it should be. So I need some input here what do I need to get in order to read as many of the built in sensors/parameters that I can ? I have a trany,pyro,and boost gauge now. Please let me know what realistically I need to hook up to this thing to get as much info as I can. I do not want to spend a $hit ton of money so if there are products out there that you guys use that work please let me know what they are and where I can get them for a decent price.
Thanks for any and all info.
Chevydog is offline
post #2 of 6 Old 07-03-2014, 10:25 PM
alaskan155's Avatar
Quoted: 60 Post(s)
cheapest is android device, bluetooth adapter and torque program.
2nd is scangauge 2
and most expensive is auto enginuity scanner
all have there pros and cons, all can read the ecm parameters in real time.
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #3 of 6 Old 07-03-2014, 10:35 PM Thread Starter
How about the dash command for the wifi ( iPhone is all I have ) will that work the same as the torque app for android ?
Chevydog is offline
post #4 of 6 Old 07-04-2014, 08:53 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I use the infinity, cost a bit more but it's awesome
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 6 Old 07-04-2014, 06:12 PM Thread Starter
What is the infinity ? Is it a stand alone gage or an app ?
Chevydog is offline
post #6 of 6 Old 07-08-2014, 07:50 PM Thread Starter
I picked up the OBDii wifi adapter and the dashcommand app for my iPad yesterday just to play around a little and see what sensors I can look at.
So my question is ......what should I be looking at/monitoring ?
I just want to see if my truck is running as it should or if I need to repair/replace anything.
Thanks
Chevydog is offline
