WTF? Failed Safety for a dash brake light!!! - Ford Powerstroke Diesel Forum
 6Likes
post #1 of 28 Old 07-02-2014, 06:21 PM Thread Starter
Yep, got rejected safety test for no "brake" light on dash. I searched this forum for answers to no avail. Anyone with fresh ideas I would appreciate it.
So I do have the brake light illuminating for 1 second upon starting truck as with all other lights (ABS, 4x4, door ajar.. etc). That eliminates bad bulb idea. My connector is clipped on tight to the ground switch above the parking brake. The spring plunger on the switch is nice and "springy" with no resistance. The rubber bumper on the foot pedal is attached appropriately. I do have continuity current in the switch. So now where do I go from here? Any fuses for the line going to the switch? I have 15 days before I have to cough up another $35 for a safety. Thanks much-
goosefrabba
BNMLUTZ is offline
post #2 of 28 Old 07-02-2014, 06:43 PM Thread Starter
Brake light appears only after turning over engine, not on accessory turn.
goosefrabba
BNMLUTZ is offline
post #3 of 28 Old 07-02-2014, 08:27 PM
alaskan155's Avatar
Quoted: 65 Post(s)
All the red brake light is for is the e brake. That's it. .. the yellow abs is a abs fault. .... if its a 02 or 03 you can go into dianostic mode and test all the gauges and lights in the digital odo.
Pull the cluster out and get a volt meter and see if you are getting 12volts when the e brake is engaged to the pins on the plug on the back of the cluter and that both sides of the switch when engaged on the ebrake are getting 12volts.
The
2002 F250 7.3/JW Tow master 4r100 212k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles, Redhead steering box
alaskan155 is offline
post #4 of 28 Old 07-02-2014, 09:06 PM
sbluke55's Avatar
Quoted: 590 Post(s)
Garage
I would run a jumper from the wire to ground and see if it turns on. If it does replace the switch. The switches go bad quite often from releasing the e brake and letting bang up into the switch. Then I would start pulling the dash apart.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #5 of 28 Old 07-03-2014, 05:38 AM Thread Starter
BTW. It is on late 1999 and is NOT the ABS light. I did unplug the wire from the switch (so light should be on) followed the wire up to the larger mess of wires where it then disappeared into. I then lightly tugged and wiggled the jambalaya and noticed the light on the dash. SO I am guessing here that there is a short in the wire. Now to figure out how to get that one wire out of that mess and fix it. Hey all in the name of "safety" right??
BNMLUTZ is offline
post #6 of 28 Old 07-03-2014, 07:19 AM
ZMANN's Avatar
Quoted: 1785 Post(s)
does the safety check include looking for all the bulbs illuminating at key on ?
We Miss you Ronnie
ZMANN is offline
post #7 of 28 Old 07-03-2014, 08:16 AM
Heavy_GD's Avatar
Quoted: 1656 Post(s)
Feedback Score: 3 reviews
I'd find a new inspection station.
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is offline
post #8 of 28 Old 07-03-2014, 08:19 AM
sprksonu's Avatar
And this is why i love Arizona....... inspections are a joke............
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #9 of 28 Old 07-03-2014, 08:33 AM
ZMANN's Avatar
we don't even have a safety inspection in AZ
We Miss you Ronnie
ZMANN is offline
post #10 of 28 Old 07-03-2014, 08:52 AM
Airborne CIB's Avatar
I live in Arizona and yes we don't have safety inspections. I assume safety inspections also include insurance verification and licence verification. I have been involved in 4 accidents that have not been my fault and not one of those drivers had insurance and only 2 of the 4 had valid licenses.
But then again I consider inspections a violation, so I prefer to protect myself with a great insurance policy while encouraging no more regulations on the books. Maybe just enforce the current law of driving without insurance is a crime?
Glendale, AZ
'05 F250 XL Extended Cab - 2 Wheel Drive, No Options Except: Integrated Brake Controller, 3.73 w/ Limited Slip, Upfittter Switches & AC
Added: Edge Monitor with EGT, Fuel Pressure, coolant pressure, low oil pressure system sensor & Ambient Temperature Sensors, turbo timer & back up camera. High Idle Mod. Manual Fan Mod, Power fold/power extend mirrors. Bullet proof EGR cooler & Remote OEM Oil Cooler.
Installed: Cruise Control w/ Leather Steering Wheel, 17 Alloy Rims off XLT, 40 20 40 Vinyl Front Seats
Well maintained with Motorcraft parts, over 228k miles and still have original head bolts.
Airborne CIB is offline
The Following User Says Thank You to Airborne CIB For This Useful Post:
heykw (07-03-2014)
