Converting L shaped Steel transfer to Auxillary - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-02-2014, 03:20 PM Thread Starter
I have an L shaped steel transfer tank that I would like to drill and weld a 3/8 inch nipple with shut off to make it a combo Transfer/ auxillary tank for long trips to Fla. so my lazy a$$ would not have to stop to fill up.
I do not run veggie oil which I know will eat up the epoxy liner in the tank. Is this doable or is there something else I am missing, possibly an additional vent in the top (the fuel filler cap is vented)
cokerta is offline
post #2 of 6 Old 07-02-2014, 03:42 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
May want to vent the transfer tank so it flows properly into the regular tank, you should be good other then that
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 07-02-2014, 09:00 PM
sbluke55's Avatar
Quoted: 588 Post(s)
Garage
Most caps for those tanks are vented for pressure and suction. Do you plan on running it straight to the pump and use a selector switch like an obs or do you plan feeding your you primary tank?
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 6 Old 07-05-2014, 08:57 AM
alaskan155's Avatar
Quoted: 65 Post(s)
this is my setup
going to order a 12v electric valve soon so i can open and close it in the cab.
just brazed a fitting into the filler neck and connected my hose, if i forget to close the aux tank it just backs up behind the cap and stays in the tank vs the ground if you use the vent tube.
just a basic gravity feed setup, all i run is the factory deezee vented cap
2002 F250 7.3/JW Tow master 4r100 212k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles, Redhead steering box
alaskan155 is offline
post #5 of 6 Old 07-06-2014, 06:43 AM Thread Starter
My plan was to gravity feed into my filler hose like Alaskan has done, If I do that will I have to add a separate vent to the L transfer tank? If I leave the valve open all of the time will I experience spillage?
cokerta is offline
post #6 of 6 Old 07-06-2014, 06:50 PM
alaskan155's Avatar
Quoted: 65 Post(s)
no the vent-able cap works fine, you can leave it open all the time but i don't recommend it, the fuel cap wasn't designed to have fuel constantly push up against it. i have accidentally left mine open a few times now and it doesn't leak out with my setup.
