96 7.3 powerstroke slow starter... - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-21-2006, 01:06 PM Thread Starter
jdg
I have a '96 powerstroke that slow starts the first start of the day. Once it has been started it it restarts without difficulty all day. the batteries are new. I have never had the glow plugs changed--I don't even know where they are---nor have I changed the starter. (It seems to crank a bit slow even with new batteries) My questions are 1) where are the glow plugs, 2) how do I check and or replace them, and 3) do you think it is the starter, glowplugs or both?
First post. Great site. thanks.
jdg is offline
post #2 of 4 Old 12-21-2006, 02:39 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
I would check your battery cables first.
The glow plugs are located under the valve covers.
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #3 of 4 Old 12-21-2006, 08:53 PM
jbawilliams's Avatar
I had a 96 that was slow to crank, and I put new batts in it. It was slightly better until it got cold, then it would not start very easy the first time for the day. Eventually the starter quit (possibly due to the extra cranking). I replaced the starter, and it cranked at about 1000 MPH! It started very easy after that. Moral of the story - don't rule out a starter as a possible cause of poor starting.
No trees were harmed in the sending of this message, however, a large number of electrons were terribly inconvenienced.
jbawilliams is offline
post #4 of 4 Old 12-22-2006, 05:56 AM
Thats Mr. Oil Leak.....
MrJohnWayne's Avatar
Quoted: 5 Post(s)
I agree with Pipelayer. I'd check you battery cables first just to make sure you have a tight connection. I just put batteries in my 250 work truck and it had the same symptoms, it ended up being a loose ground on the right side battery.
John Wayne
Owner and Operator of the
REDNECK VALDEZ
You can find me on
MrJohnWayne is offline
