Mico Lever Lock Installation - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 11 Old 06-30-2014, 09:14 PM Thread Starter
tristanlee85's Avatar
Send a message via AIM to tristanlee85 Send a message via MSN to tristanlee85 Send a message via Yahoo to tristanlee85
After searching around on numerous forums, I didn't find any real write-up on installing this so I figured I'd post pictures of my setup.
I was tired of having to drop the truck in 4LO low gear on the boat ramp while still being paranoid about it rolling into the water so I decided to get a brake line lock. I went with the lever lock for ease of use and installation, but there are a number of other options available depending on how serious you are able keeping the wheels locked. Here are a few pictures:
I took the time to also install an inner and outter grommet on the firewall as well to keep things clean and quite. The brake hoses seemed to be the easiest option rather than bending line, but certainly more expensive with the AN fittings. As you can tell this only locks the rear wheels which is plenty for my use.
I am more than satisfied with this. I docked the boat tonight with a little piece of mind too.
7.3LDriver likes this.
Tristan
1999 F-250 SD
tristanlee85 is offline
post #2 of 11 Old 08-19-2014, 09:04 AM
Captain Starbucks's Avatar
Nice write up!
I was actually just going to do the exact same thing for the exact same reason and it looks like you already paved the way for those of us lucky enough to have an extra pedal. I don't suppose you happen to have the part numbers and supplier information for the lines?
Also, did you hook up the horn wires?
Rob
2001 F-250 7.3 4WD CC LB,SB CON OFE clutch, DIY 6637 intake. Superior compressor, 4"SS Magnaflow
DP-Tuner:Hi idle,60T,80T,80E,120. Diprocol boost/pyro. Overboost Annihilator. Hi-Flow turbo outlet.
4" Superlift. Springs/blocks w/ Bilsteins. 315/75-16 Toyo M/T's. 35" spare underneath. Truetrac
Alpine deck, Infinity 6x8's, Kicker Comp 10", JBL 6x60 amp, 1.2 MFD cap.
Glasstite High Rise Cap. 7,800 empty weight.
Captain Starbucks is offline
post #3 of 11 Old 08-19-2014, 09:49 AM
ZMANN's Avatar
Quoted: 1586 Post(s)
I like it but I would choose to lock the front wheels if it was mine I looked into Mico and the roll controls a couple of times but for now i just chock the front tire
i have seen trucks get the rear end buoyant when the boat is loaded on the trailer and a big wave comes plus the E brake locks my rear ( I keep it functioning well unlike most )
We Miss you Ronnie
ZMANN is offline
post #4 of 11 Old 08-20-2014, 03:00 AM
Can you tell me how to get the most out of my parking brake? I can't see two tiny drum brakes in the rear holding 19,000 pounds of my two favorite toys just inches above a salty death.
I've tried to adjust it in the past, I believe it works how it's supposed to, but it's about 20% of what it needs to be to keep 19,000 pounds from rolling into the saltwater. Either way, I think I'll do the Mico, but it would be handy having a parking brake that works better than new.
Rob in Seattle.
post #5 of 11 Old 03-14-2015, 05:44 PM
I finally got around to installing my Mico lock today. I did basically the same as the other guy, but I used hard lines instead.
Parts list was pretty simple once you get the Mico lock.
30" 1/4 inch brake line
40" 1/4 inch brake line
1/4 union
Line bender
jug of brake fluid.
Grommets for the firewall
dremmel for enlarging the firewall hole. It needs to be pretty big to stuff two 1/4" fittings through there.
Took pretty much the whole day but totally worth it. I stopped on a really steep hill, put her in neutral, set the Mico and she held and held. No leaks, no pressure drop, I love this thing. Wish I would have done it years ago. No driving off with this thing set either, it'll stall the engine.
post #6 of 11 Old 03-15-2015, 06:17 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
I want to add this to my truck also but plan to install the mico unit in the trans tunnel near the transfer shifter. I dont like the idea of brake lines inside the cab. Also keeps the lines needed shorter. Boss gave me an old one but it doesn't seem to work but gave me food for thought. If I can rebuild it to working condition I will install it.
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #7 of 11 Old 03-15-2015, 06:25 AM
ZMANN's Avatar
you want short lines and if that unit you have is no good consider the Mico electric unit
it would plumb in right at the master https://www.mico.com/products/brake-...activated-lock
We Miss you Ronnie
ZMANN is offline
post #8 of 11 Old 03-15-2015, 08:38 PM
dnf12908's Avatar
Quoted: 31 Post(s)
I had the electric Mico Lock setup on my old work truck...worked great, just a toggle switch on the dash.
Darrell
'03 F-350 6.0L C/C SB FX4 SRW
SCT X3 w/tunes by MKM
MBRP exhaust-turbo back
EGR delete
ARP studs
OEM gaskets
ELC coolant & filter
MTW Stage 1 turbo w/billet wheel
FPR (blue spring)
'04 upgraded front cover
BPD fan clutch adapter/w 7.3 fan
stator delete
All-aluminum intercooler(upgraded OEM unit)
Amsoil bypass oil filter
Insight CS monitor
Harley headlights
2008 rear diff. cover
EnviroSave powertrain treatment,
dnf12908 is offline
post #9 of 11 Old 03-16-2015, 06:26 AM
Mico does offer a rebuild kit.
I don't blame you for not wanting brake lines in the cab but it's not the end of the world, just inspect for leaks often.
post #10 of 11 Old 03-16-2015, 06:28 AM
ZMANN's Avatar
it's not bad like a fuel or motor oil pressure line in the cab ;-)
We Miss you Ronnie
ZMANN is offline
