Fuel Pump issues, how can I tell? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-30-2014, 08:54 AM Thread Starter
Truck left me stranded 90 miles from home last night...just quit like it ran out of fuel. This morning at the house, I verified voltage at the positive terminal, made sure inertia button pressed down, but when I opened the fuel bowl drain, get no pressure when I expect the pump to be running. When I put my hand on the pump body I feel a slight jump when its supposed to start, but no vibration at all, and again, no pressure at the fuel bowl drain. Can I safely assume it's the pump?
Please help!
Thanks,
Mike.
mjkten is offline
post #2 of 10 Old 06-30-2014, 10:51 AM
heykw's Avatar
Is the lid on the filter housing, with a filter installed?
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #3 of 10 Old 06-30-2014, 10:59 AM Thread Starter
Yes, lid is on...having no luck pulling old pump, bracket nuts spinning on their bolts, can't figure out how to remove line from tank. Videos I have seen show a clip being pulled before pulling off line, there doesn't seem to be a clip on this one...getting frustrated.
2003 7.3L
NRA Sticker on back window
Missing muffler mod
Potential by Ford...
6.0 Trans cooler now installed.
“Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote.” Ben Franklin, 1759
mjkten is offline
post #4 of 10 Old 06-30-2014, 11:11 AM
STANGMAN893's Avatar
Pull the hose off and check if any fuel comes out. Better with help and a quick turn of the key. Mine made all kinds of noise and all just no flow. Pulled the hose and nothing.
STANGMAN893 is offline
post #5 of 10 Old 06-30-2014, 02:14 PM
sbluke55's Avatar
Quoted: 523 Post(s)
Garage
You need a special tool to remove the fuel lines from the pump. Attachment 306618heres a pic. Where's your tank level at? If it's below 1/4 add 5 more gal and see if it primes up.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #6 of 10 Old 06-30-2014, 02:29 PM
Got mine from Autozone but mine are 4 colors instead of one tool.
post #7 of 10 Old 06-30-2014, 04:16 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I actually just finished fixing the EXACT same issue, you gonna need a fuel line removal tool, a flat head screw driver and an 8 and 9 mm wrench to swap the pump out
Mine made noise and did nothing, got a new pump in this afternoon installed in 10 minutes and I'm rolling again
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #8 of 10 Old 06-30-2014, 05:47 PM Thread Starter
I bought the combo pack from Advance Auto, it worked fine on the high pressure side. The tank line kept giving me fits, supposed to be some sort of clip you pull out (with that flat bladed screwdriver) but the "clip" turned out to be a narrow blue plastic band with no accommodation for removal...the more I mess with it the more I appreciate the real mechanics who do this for a living, efficiently. I'd starve as a mechanic!
2003 7.3L
Missing muffler mod
mjkten is offline
post #9 of 10 Old 06-30-2014, 07:46 PM
sbluke55's Avatar
Quoted: 523 Post(s)
Garage
Take a pic and post it up.
01 f-250, Standard
post #10 of 10 Old 07-04-2014, 10:01 AM Thread Starter
I had limited time and less patience, so I sent it to a "real" mechanic. Fuel pump. Symptoms identical to running out of fuel, because that's what it did to the engine. My troubleshooting efforts checked voltage at the positive terminal which verified relay and fuse good, opening fuel bowl drain with pump run demanded no pressure. How to remove that rear fuel line from the tank will remain a mystery to me. Sorry, and thanks for your efforts to help.
Mike.
2003 7.3L
Missing muffler mod
mjkten is offline
