What should i upgrade before i program? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 06-30-2014, 07:51 AM Thread Starter
SwiggitySwooty's Avatar
I have a 99 F250 SuperDuty that has 241k miles that has never been programmed in its life time.
I was told before I put a programmer on it i need to upgrade my Intake, Exhaust, and I need to get 3 gauges Boost, Exhaust temp, and Tranny Temp.
Is there any other Mods or Upgrades i should look into before i program it and run the risk of breaking something?
SwiggitySwooty is offline
post #2 of 15 Old 06-30-2014, 08:13 AM
Joel's Avatar
Quoted: 10 Post(s)
That's a very good start.
The only other thing to add would be a billet turbo wheel to eliminate surge.
Then you will have a great running truck that should keep you happy for a while.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 15 Old 06-30-2014, 10:29 AM
blue99stroker's Avatar
Quoted: 246 Post(s)
x2 on billet wheel best perf mod for stock truck besides a chip.
if you notice the trans getting a little hot a better cooler will be a good idea too.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is online now
post #4 of 15 Old 06-30-2014, 10:33 AM
Not to hijack but what should the trans temps be? I just put a cts on mine and it was 177deg empty.
-3Deez
2014 Ram Crew Cab 6.7
2001 F350 Crew Cab 7.3
3Deez is offline
post #5 of 15 Old 06-30-2014, 11:13 AM
Joel's Avatar
Quoted: 10 Post(s)
On a hot day that's fine. Don't worry about it till you start pushing 220 or so.
I'm still running the stock cooler and mine never gets hot, even towing through the mountains.
Now that's not to say that a better cooler isn't a good idea. Just saying watch the gauge and go from there
Joel is offline
post #6 of 15 Old 06-30-2014, 11:19 AM
Raul@Stealth Automotive's Avatar
thats a great start... but i will also add: start saving your money for an upgraded transmission. With that many miles on the truck i doubt the stock trans is going to hold up that much longer.
If you need any help with prices on parts ore recommendations let me know.
-Raul
Raul@Stealth Automotive is offline
post #7 of 15 Old 06-30-2014, 11:53 AM
hansel's Avatar
Quoted: 94 Post(s)
Also might think about putting about $250 aside for a John Woods valve body, my transmission had some shifting issue's but the JW's valve body cured it
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #8 of 15 Old 06-30-2014, 04:48 PM
Justin@DP-Tuner's Avatar
Quoted: 45 Post(s)
What you have listed is a great place to start. Intake and exhaust help the air get in and out quicker, while the gauges are cheap insurance so you do not cause preventable damage. I would say a tuner is a great next step after those mods. Once you have the tuner, sky (and money) is the limit as far as power goes. Injectors, turbo, HPOP, etc. will just continue to increase power, and a custom tuner can write tunes specific to those mods.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is online now
post #9 of 15 Old 07-05-2014, 08:50 PM
Quoted: 3 Post(s)
Why is that? A friend of mine ordered a WW2 (billet) and before it showed up, he picked up a brand new 38R dirt cheap. I can get the billet wheel, but not sure it'd do me any good. Mine is a '03 CCSB, 100% stock other than the 6637. Is there any benefit to the billet wheel on a stocker like mine?
junkyardwarrior is offline
post #10 of 15 Old 07-05-2014, 09:44 PM
Rodslinger's B1TCH
it will boost up quicker and there is a good chance your original intake wheel is worn out slightly.
steve604 is offline
Tags
7.3 4x4 programmer
