New 7.3 owner, towing questions - Ford Powerstroke Diesel Forum
post #1 of 18 Old 06-29-2014, 09:18 PM Thread Starter
SouthWest350's Avatar
I just bought an 02 350 with the 7.3 to tow my 27' toy hauler. Truck has 130k miles, 6" lift with 35" tires. Other than an AFE CAI the engine is stock. My last truck was a 2011 f150 ecoboost that pulled my 7500lb trailer like nothing. Today I pulled the trailer home from storage with the 7.3 and I think something isn't right.
The diesel is very loud when towing compared to empty. Is that normal? By loud I mean it sounds like electric fans on high when an engine starts getting hot. Although the engine and tranny temp gauges didn't move at all as I was towing.
I have to rev up to 2500rpm to get the truck moving any faster than granny speed when taking off from a stop. Is that normal?
Sometimes during startup it idles normal then I hear what sounds like an exhaust leak within a minute or two. If I blip the throttle it goes away. Then while driving it comes back. It sounds like it's coming from near the turbo.
I bought a diesel over the v10 for its towing capabilities but I'm disappointed with the performance of this 7.3 so far. My old f150 could run circles around this f350 which leads me to believe something is not right.
I have no aftermarket gauges yet. I plan to buy the Edge insight this week. Does that display boost pressure out of the box? Or does it require a sensor and addition wiring?
Any help is greatly appreciated.
SouthWest350 is offline
post #2 of 18 Old 06-30-2014, 04:07 AM
ja_cain's Avatar
Exhaust leaks on these trucks will totally kill boost production and thus power. Also, need to check out whether or not the ebpv (exhaust back pressure valve) is sticking. If you get the edge insight you should be able to read boost through the map sensor without the add on sensor. This would be instrumental in figuring out your power issue as you can also read exhaust back pressure too. Also, look around the exhaust manifolds and up pipes (fire wall) for soot as this would definitely indicate a leak. Google boost leak detector and build one so you can check the induction system for leaks. Btw, you can also get an obdII blue tooth reader and torque app if you have an android device for about 30 bucks total and it will allow you to monitor boost, exhaust back pressure and all of the major injection parameters. Definitely well worth the money. Good luck!
2002 F-350 SCLB PSD 4X4 6 Speed
ja_cain is offline
post #3 of 18 Old 06-30-2014, 04:31 AM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 20 Post(s)
Post some photos of the truck and any other stats in your signature. Everything sounds normal to me! A stock-tuned, lifted 7.3 with 35s AND towing heavy will take some RPMs to get off the line. Coming from an EcoBoost, the 7.3 will feel like a slug-powered brick.
That exhaust leak sound youre hearing is your EBPV. This valve is your friend in the winter but if it malfunctions, can be a backstabber. Check the EBPV at the turbo for any oil leaks and proper movement. Yours shouldnt be activated during these summer months.
This site is amazing in finding archived info and receiving new input with any post you submit. Enjoy your 7.3 and have fun with this site
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is online now
post #4 of 18 Old 06-30-2014, 04:49 AM
Montstroke's Avatar
And once you have done all that, tuning it will make a world of difference too. I read all the rave reviews as such, but can not believe just how much better/stronger the truck runs and with the auto tranny, the shifts are also much improved.
2001 F250 CCSB
Less than cold air intake
RR Billet Wheel
EBPV gone
AIH gone
Turbo back 4" MBRP muffled
6 PHP tunes
315's with Zone level kit
On board air
Suspension air bags
Montstroke is offline
post #5 of 18 Old 06-30-2014, 05:10 AM
E-Man's Avatar
Quoted: 5 Post(s)
X2. Exhaust leaks will cause what you are describing. For example, when I was installing my EGT probe in my driver side exhaust manifold I drilled the hole, then I had to drive the truck to the store for a part. The probe was not installed yet and the hole was open creating a big exhaust leak...my truck was a complete slug during that short drive. I felt like I was towing a building even though I was empty.
When you have to increase RPMs to get off the line when towing does it eventually 'hit' and take off? That would be when you build enough boost and there is a noticeable power increase. If your truck isn't hitting, I'd say exhaust leak somewhere.
2001 F-250 CC SB 4x4 Off-Road w/ 88k miles on the 7.3. 4" lift on 35" BFGs. All synthetic fluids (Amsoil & Schaeffer's)
S&B intake, 4" turbo-back straight-pipe, 6.0 trans cooler, Dieselsite coolant filter w/ Delo ELC, Isspro gauges, Mag Hy-Tec diff cover
2012 tailgate, rear bumper, and tailights
2001 Excursion Limited
Only 55k miles on the 7.3
Bone stock
E-Man is offline
post #6 of 18 Old 06-30-2014, 05:41 AM
hansel's Avatar
Quoted: 100 Post(s)
The post above have great tip's, but a stock 7.3L is kinda a dog on feeling like it's a hot rod it will full like a freight train, but it's not going too knock it out of the park off the line.
I've just picked up a 2001 7.3L CCRSW 4X4 that has been kept in good shape as far as the body, but the engine with 225K has needed some TLC, I've changed all the fluids and filter's, and have been giving it a fuel mixture of Diesel Kleen and TC-W3 2 stroke oil too help nurse the injector's.
If you are towing I recommend replacing the stock transmission cooler with the 6.0L or the Dorman 918-216 model, also throw some gauges on her, Diesel Manor has some good pricing on gauge kit's.
One of the best investment's is a PHP Hydra Talk about waking up a truck
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #7 of 18 Old 06-30-2014, 08:28 AM Thread Starter
Thanks for all the tips. First thing today after work I'll unplug the backpressure valve and see if that helps. If I leave it unplugged is there any reason to clean the sensor tube?
I've read the 7.3 was a slouch but I wasn't expecting this. My wifes Tahoe hybrid can pull just as hard haha. I gotta get it fixed for vacation this weekend. I'll be pulling the trailer up to 6500ft.
post #8 of 18 Old 06-30-2014, 12:02 PM
E-Man's Avatar
Quoted: 5 Post(s)
Reliability is the strength of the 7.3; they definitely don't compare to the new diesels with regards to power. But if you're saying your gas powered Tahoe tows comparably, I'd say there has to be something robbing your truck of power. My wife's 2001 Excursion 7.3 is bone stock and I just pulled a 24x8.5 enclosed car hauler with an El Camino inside (roughly 7500-8000 pounds total) 700 miles round trip and it pulled well. Don't get me wrong I felt it back there, but I never felt like I was underpowered or couldn't pass a slower vehicle.
Bone stock
E-Man is offline
post #9 of 18 Old 06-30-2014, 12:19 PM
Quoted: 3 Post(s)
I had a 2007 Yukon denali (6.2L) and my 7.3 pulls 10x better. There is something wrong with your truck!
2001 F-350 4x4 7.3
2015 AXIS A24 surf boat
2012 Keystone Outback Travel trailer
r33pwrd is offline
post #10 of 18 Old 06-30-2014, 01:00 PM
hansel's Avatar
Quoted: 100 Post(s)
One thing I forgot, even thou the truck has only 130K also look into having the fuel pick up and the 2 filter's inside the tank service, some guys "hutch mod" their tanks, I just had my diesel guy clean mine, and it made a difference for sure.
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
