chipped or not? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-29-2014, 07:07 PM Thread Starter
chipped or not?
purchased a 2001 excursion 7.3l turbo diesel and was told it was 100% stock.
the trans shifts HARD, and it rolls coal pretty good (blowing smoke under decent throttle) is that indicative that its probably chipped? how can I tell/check for certain?
thanks guys!
amerimuscle is offline
post #2 of 6 Old 06-29-2014, 07:23 PM
Quoted: 780 Post(s)
Hook up diagnostics and monitor numbers
Corey@CNCFAB is offline
post #3 of 6 Old 06-29-2014, 08:01 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Never seen a stock one smoke, and is it shifting hard like it's going out, or a firm shift like a race setting? If the latter then you should send the PCM off for a re flash of stock settings
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 6 Old 06-29-2014, 08:34 PM
Joel's Avatar
Quoted: 10 Post(s)
The only way it will smoke stock is if there is a major problem.
Is it painfully slow to drive? If not, it's chipped
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #5 of 6 Old 06-29-2014, 08:50 PM
03ranger30's Avatar
The dealer can reflash your PCM to stock settings IIRC.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
The Following User Says Thank You to 03ranger30 For This Useful Post:
Corey@CNCFAB (06-30-2014)
post #6 of 6 Old 06-30-2014, 05:33 AM
Quoted: 780 Post(s)
What he said. But if there's no visible chip, its probably got a tune downloaded to it. If it smokes that bad, and seems pretty fast, I would not tow with it.
