ABS light on, cruise control not working. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-29-2014, 08:20 AM Thread Starter
I recently purchased a 99 F450 cab and chassis truck. The ABS light has been on since I bought the truck but there seems to be no problems with the brakes. I read that the speed sensor on the rear end could have something to do with it.
tjduke is offline
post #2 of 5 Old 06-29-2014, 02:20 PM
heykw's Avatar
Does the speedo work?
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #3 of 5 Old 06-29-2014, 02:48 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Not to be rude but questions like this are irritating...
If the light is on.... CHECK THE CODE.... Yes an ABS code on our trucks can cause shifting problems, cruise problems, loss of speedo etc.
We don't magically know what's wrong.. The light could be completely unrelated to your cruise not working... Only way to tell is with a scanner
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 5 Old 06-29-2014, 04:42 PM Thread Starter
Well I used a scanner from the snap on guy and nothing came up. I wouldn't be on here asking for help if I did not already do this. Thanks anyways.
tjduke is offline
post #5 of 5 Old 06-29-2014, 04:47 PM
schlutzer's Avatar
Quoted: 18 Post(s)
You have a light, that means you have a code. What you apparently don't have is a scanner that can read ABS codes or you didn't tell it to.
Without knowing what that code is you are just guessing
