Help!! 1999 7.3 F-350 weird loss of power - Ford Powerstroke Diesel Forum
post #1 of 21 Old 06-28-2014, 10:39 PM Thread Starter
Hey guys i'm new to this forum and to diesels. I just got my first 7.3 about a month ago and I fell in love. But... about a week ago there was just a sudden loss of power. I got home and shut it off for a while started it up and drove it to my mom and dads with no problem. I went to leave and started up the hill and there was no power to climb it. I even put it in low gear. After it stalled 3 times I finally got it up the hill but it stalled 2 more times. I only live about a mile from my parents. After I replaced the UVCH and the glow plugs and GPR changed all the filters and oil it finally goes but still loses power out of no where. I can turn it off and start it back up and its fine for a little while. When it loses the power though it feels like its not getting fuel even though it has 60psi. I looked at the injectors and sleeves and they looked good. The SES light isnt on. And the tach moves when I start it. Its an easy crank too.it has a little white smoke when I first start it but I found out thats normal. When it loses power though it has alot more white smoke and the exhaust sounds weird and the turbo doesnt spool out but it will get to 2,000 rpm's and no more when I hold the pedal to the floor. I checked the HPOP reservoir and its where it's what I would call full (about a half inch from the top from what I could see.) I greatly appreciate any help I can get. Sorry if theres any more threads that are about this. Lol ive been looking for a week and havent found anything like what i'm having trouble with
david j is offline
post #2 of 21 Old 06-28-2014, 10:44 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Do you know your fuel pressure, idm good, how's the idle sound? Choppy like half an engine? Ipr DC? Good luck I hope more knowledgable people can help too
Welcome to the org btw
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
The Following User Says Thank You to 351fifty For This Useful Post:
david j (06-29-2014)
post #3 of 21 Old 06-29-2014, 12:09 AM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
Id check for codes first. The cheapo scanners don't work on our trucks. You have to get a scan gauge or the torque app and blue tooth adaptor or take it to a shop and have the codes pulled. Is the nut on your ipr tight? Unplug your icp and look for oil in the connector. So you have a gauge on your fuel? Where us it? When was your last fuel filter?
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
The Following User Says Thank You to sbluke55 For This Useful Post:
post #4 of 21 Old 06-29-2014, 12:20 AM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
There is also auto enginuity for your lap top.
01 f-250, Standard
post #5 of 21 Old 06-29-2014, 10:07 AM Thread Starter
I dont have the gauge for the fuel. I have a family member that's a state mechanic and he pulled the psi for me and it was at 60 for the fuel pressure. I checked the nut on the ipr and for oil on the the icp.I live in bowling green ky so I went ahead and unplugged the fuel bowl heater too just in case it decided to short out on me later and it hardly ever gets down to 15 degrees so i should be good. Where can I get a scanner or the bluetooth scanner at and how much? That and I know on some older vehicles you can turn the key on and off so many times and something will flash at you so many times for codes. Do our trucks do that? And I changed the fuel filter at the same time I did the oil. It only has about 5 miles from test drives. I know that this is a stretch but would a bad turbo assembly (bearing and wheel ) cause this? Again thanks for the help.
david j is offline
post #6 of 21 Old 06-29-2014, 10:40 AM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
When he checked the fuel pressure was it just at idle? Or was it under load when it starts to cut out? Scan gauge can be found at almost every part store for $150, blue tooth adaptor needs ordered on line for $20 plus the $5 torque app for android. IPhone needs and $100 (I think) adaptor and a $5 dashboss app. Auto enginuity is $360 from riff raff. Dash boss and ae can do a buzz test and contribution test. Bad turbo could be it but you should of heard it going out. Quick test for the turbo is pull the intake off and grab the compressor wheel and pull and push it wiggle it. If it moves any at all its bad besides spinning.
01 f-250, Standard
post #7 of 21 Old 06-29-2014, 11:02 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Also need to look at your ICP under load.
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
The Following User Says Thank You to HVAC SuperTech For This Useful Post:
post #8 of 21 Old 06-29-2014, 08:28 PM Thread Starter
Alright. I'm gonna stop by autozone tomorrow and pick up the tester. And he had me rev it to 2500 rpms for 30 sec to make sure it was a constant pressure. I had a neighbor come down and offer help today. He said he had thought he had seen blue smoke and thought it sounded like a head gasket. Any ideas on that? I did make an idiot mistake and put straight grade 30w oil in it when I first got it and I thought I had killed the motor. Lol. But it hasnt used any oil or coolant that I can notice. Could a cracked head gasket give these symptoms?
david j is offline
post #9 of 21 Old 06-29-2014, 09:38 PM
Joel's Avatar
Quoted: 10 Post(s)
I don't have time to read this right now, but I'm commenting so I remember to read it later and offer any help I can if you still need it.
Good luck until then
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #10 of 21 Old 06-29-2014, 09:51 PM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
30w is ok as long as it's not cold out. I wouldn't recommend it all the time but once you should have no problems. Head gasket, probably not. Blue smoke is oil. When started pop off the oil cap and flip it over and set it back on the oil fill tube. If it rattles of your good if it blows off it's bad. It means you have blow by or a bad cylinder which means new motor. When you get your scan gauge you can set it up to read icp(high oil pressure) and ipr (high pressure oil regulator). Icp should be 800ish at idle and driving around should be 1500 to 3k and around 3k under wot. I have hpop problems and can only hold 2200 at wot. Ipr should be 10%ish at idle and driving around is about 25%-50% depending on throttle position.
01 f-250, Standard
