LEAK!!!! HELP!!!!
ok so i didn't drive my truck today cuz i didn't have time to start it this morning to make it to work on time. so it sat all day and this afternoon i started it and i knew it would be hard to start but it was a little harder then i thought. well it fired up and i noticed bluer smoke than normal and also after it ran for a while i noticed i had fluids leaking under the front and i think it id fuel. it is leaking of what looks like a drain hose but i am not sure
can anyone lighten me on what these might be thanks |
Is the hose along the side of the engine and drains on the crossmember under
the engine? (unless you have attached a hose to it)... If so, those little o-rings have a tendency to go bad. Do some searching and there are posts that have the size of them that you can buy. Ford wants a bunch for them. |
sounds like your drain tube for the fuel bowl
yea i have found the site the tells you about the o-ring fix i thought it sounded like that was it i just wanted to make sure
i am guess that is what is goes to the hose was there when i look and i havent added anything to it i got the truck used so i am going to do some huntin on the find out tomorrow thanks |
As already said it is the fuel bowl drain O rings. When the switch was made to ULSD they began leaking like crazy. Ford has made a mint fixing this issue. I can't believe mine have never leaked!!
NCH |
