Dual Tru-Cool 4739's for transmnission cooling? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 06-26-2014, 06:02 PM Thread Starter
McKinneyMike's Avatar
Do you think that it would help lower temps? I was concerned about load on fluid flow if I stacked two of them. Is it a non-issue?
2000 F250 SD 2WD 7.3L
RiffRaff billet compressor wheel
PHP Hydra
4" Diamond Eye, turbo back w/5" tip
ISSPRO EV2 Pyro, Trans Temp, Boost and Fuel Press
Kenwood Exelon/Focal/Image Dynamics/PPI
McKinneyMike is offline
post #2 of 17 Old 06-26-2014, 07:19 PM
heykw's Avatar
Nonissue
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #3 of 17 Old 06-26-2014, 11:26 PM
What are you doing that you need two additional coolers? Your temps shouldnt be anywhere near that hot
2002 F250 XLT CrewCab Short Bed 4x4 7.3L
05 Conversion - 50" LED Light Bar - MBRP 4" Exhaust - AIS Intake - PHP Tuned
USA - Thank you those who serve
A/Ox3 is offline
post #4 of 17 Old 06-27-2014, 12:05 AM Thread Starter
No the temps are not super high. I was going to replace the original with two of the Tru Cool's vs a 6.0 cooler. I just found a Dorman equivalent of the 26 row Ford 6.0 cooler for $151.00 from Partsgeek.com. Anyone have any experience with these?
PHP Hydra
post #5 of 17 Old 06-27-2014, 10:39 AM
Curious... Why not just add one to the factory?
A/Ox3 is offline
post #6 of 17 Old 06-27-2014, 11:00 AM
early99psd's Avatar
Quoted: 12 Post(s)
Go with the 6.0 you will be happy with it. I had a B&M fluid cooler with fan and it didn't do the job. I got a used 6.0 cooler from junkyard $50 and $35 to have it flushed. There is a reason why a lot of people use the 6.0 cooler, they work great and easy to install.
Sent from AutoGuide.com App
MB HPOP, PHP Hydra, AFE stage 2, 4" turbo back exhaust, gutted cat, ford reman trans, JW valve body, 6.0 trans cooler, EGT trans temp boost gauges, Hutch and Harpoon mod, riffraf FRx, Pro Comp leveling kit, 1" zone shackels, 08 rear diff cover, 315 Toyo AT2,
early99psd is offline
post #7 of 17 Old 06-27-2014, 03:35 PM Thread Starter
I will most likely just get a 6.0 cooler. I was looking for alternative to a new one, but a used one is more than reasonable. I think stuff out of proportion at times.
PHP Hydra
post #8 of 17 Old 07-01-2014, 09:01 PM
I run a tru cool 4739 in line with the stock cooler pulling 11k in 80 to low 90 degree temps on flats and some small hills and tranny temp never got above 185. Have to see what happens when towing the same from 5000ft to over 11kft in the mountains.
sean andreano is offline
post #9 of 17 Old 07-01-2014, 09:27 PM
heykw's Avatar
Link to the cooler.
heykw is offline
post #10 of 17 Old 07-02-2014, 03:09 AM Thread Starter
Originally Posted by heykw View Post
Link to the cooler.
http://www.amazon.com/Tru-Cool-LPD47391-Pressure-Transmission-Cooler/dp/B0060NKA1U
PHP Hydra
