Front axle end play/ grinding-- Bearings? - Ford Powerstroke Diesel Forum
post #1 of 25 Old 06-26-2014, 02:47 PM Thread Starter
usteffenhagen's Avatar
Hey guys so I've noticed a terrible intermittent grinding sound from my driver's side front wheel. When I removed my hub lock I can move my axle spindle probably about 1/2" to 3/4", while my passenger side has very very little to no play. So, before I buy a new hub assembly, does this sound like my bearings are belly up?
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #2 of 25 Old 06-26-2014, 03:12 PM
Your axle stub simply slides through the bearing assembly. There is a bearing in there to hold it "up" but not prevent in/out motion. In which direction are you able to move the stub axle?
If you're hearing it, your unit bearing is probably toast. Can you rock your wheel?
2000 F350 4wd CC SB PSD
Normal mods plus gauges and PHP chip
Lowered to F250 height
Stock tire size, looks stock.
18' 10k# equipment trailer
30' Travel Trailer 7500#
Kioti CK30 tractor
Kawasaki KLX250s Dual Sport
Highbeam is offline
post #3 of 25 Old 06-26-2014, 03:20 PM Thread Starter
I couldn't rock the wheel but my brakes were still attached when I tried. And the movement isn't in and out, it is side to side
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #4 of 25 Old 06-26-2014, 03:29 PM
ZMANN's Avatar
Quoted: 1472 Post(s)
jack it up and rock the wheel like mentioned the brakes can be attached
excessive movement is a sign
We Miss you Ronnie
ZMANN is online now
post #5 of 25 Old 06-26-2014, 03:31 PM
ZMANN's Avatar
the stub shaft play may be a bad needle bearing located inside the unit bearing but replaceable separately
We Miss you Ronnie
ZMANN is online now
post #6 of 25 Old 06-26-2014, 03:39 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 350 Post(s)
Usually if it has that much play your stub shaft might be wore out all together. Happens when people drive around with hub locked in for too long.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #7 of 25 Old 06-26-2014, 03:41 PM
Joel's Avatar
Quoted: 10 Post(s)
I replace the needle bearings usually once before the whole hub assembly wears out.
I'd try that first for the $20 it costs
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #8 of 25 Old 06-27-2014, 08:16 AM Thread Starter
I'll see again when I get home. Where would the stub shaft be worn exactly?
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #9 of 25 Old 06-27-2014, 12:39 PM
ZackMicF's Avatar
Quoted: 29 Post(s)
i just replaced a Hub assembly on my truck, it was making a grinding noise and then finally locked up on me on the freeway, that sucked but i just threw it in first and was able to pull over!
but it only cost me $180 bucks to replace it from oriellys auto parts
its too easy to replace, takes less then an hour if your truck isnt stubborn
01 F250 7.3 CC SB 4X4 THE MOST BADASS 7.3L AROUND!!! too many parts to to list!! wont fit in the Sig. Block!!! but check out the build thread, well worth the time
BUILD THREAD^
ZackMicF is offline
post #10 of 25 Old 06-27-2014, 01:00 PM Thread Starter
Yeah last night I picked up a new assembly from Carquest for $131 out the door. I'm about to pull her into the garage and start a working.... Hopefully it shouldn't be too much of a pain. Good to know you didn't get in a wreck and your truck was okay.
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
