OBD2 Bluetooth to computer - Ford Powerstroke Diesel Forum
post #1 of 18 Old 06-26-2014, 08:51 AM Thread Starter
early99psd's Avatar
Quoted: 14 Post(s)
Has anyone used the Bluetooth obd2 plug to link to a computer, instead of a android phone? I am an iphone user and don't have an android.
Sent from AutoGuide.com App
MB HPOP, PHP Hydra, AFE stage 2, 4" turbo back exhaust, gutted cat, ford reman trans, JW valve body, 6.0 trans cooler, EGT trans temp boost gauges, Hutch and Harpoon mod, riffraf FRx, Pro Comp leveling kit, 1" zone shackels, 08 rear diff cover, 315 Toyo AT2,
early99psd is offline
post #2 of 18 Old 06-26-2014, 10:09 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Most laptops don't have Bluetooth, nor do they have the ability to be a hotspot to use a WiFi OBDII adapter. They can be made to do the WiFi one though but that's extra purchases. For a laptop you're best off just buying a USB one, or a program like AE that comes with it.
Or just buy a cheap used android phone or tablet and use that
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 18 Old 06-26-2014, 10:14 AM Thread Starter
early99psd's Avatar
Quoted: 14 Post(s)
I am using a MacBook running windows, it has Bluetooth. The problem I am having is used phones are more than I want to spend. I would rather put the money towards AE. I did not know if anyone had used a computer, and if it had the same functions as the phones.
post #4 of 18 Old 06-26-2014, 10:22 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Bluetooth, even if you can find a windows program to run it, will never be as good as a wired connection. In the same was Cat6 Ethernet cable will out do even AC ( the newest) WiFi technology in terms of data transfer volume and speed.
post #5 of 18 Old 06-26-2014, 10:24 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Locally I see generation old HTC android tablets for 50$ and down...
But so far I have yet to hear of a windows program that uses bluetooth, I'm sure its out there though
post #6 of 18 Old 06-26-2014, 10:29 AM Thread Starter
early99psd's Avatar
Quoted: 14 Post(s)
Ya on that I am not sure of. Some of the Bluetooth plugs on eBay come with a disk with some kind of software, just wondering if it's as good as the torque app. Since I don't have the android phone or tablet I am just not sure if I want to spend the money for the plug and phone. I think it would be better to put the money towards AE, unless I can find a phone for cheap or free. I wish someone would come out with an app for us iphone people.
post #7 of 18 Old 06-26-2014, 10:40 AM
schlutzer's Avatar
Quoted: 18 Post(s)
There is one... Dash command. I know little about it, but its uses WiFi rather than Bluetooth as Apple doesn't allow data streaming through bluetooth... That's the reason Torque and others doesn't exist for iPhone.
But adapters cost at least double and I've heard the app costs more too
post #8 of 18 Old 06-26-2014, 10:43 AM Thread Starter
early99psd's Avatar
Quoted: 14 Post(s)
So if it uses wifi then do I have to be in range of my network? If so then I guess it is only good in my garage.
post #9 of 18 Old 06-26-2014, 10:45 AM
schlutzer's Avatar
Quoted: 18 Post(s)
No the way it works is you set your phone up as a mobile hotspot a then connect the adapter to it. You can use it anywhere, it works the same way as if you were going to share your phones Internet connection with a tablet or anything
post #10 of 18 Old 06-26-2014, 11:21 AM
Raul@Stealth Automotive's Avatar
why not get one that does wifi for iphones?
Raul@Stealth Automotive is offline
