1999 air bag light on - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-25-2014, 08:03 PM Thread Starter
My air bag light recently came on.
What should I or can I do?
Thanks in advance
llesg is offline
post #2 of 6 Old 06-26-2014, 02:14 PM
Solid98's Avatar
Quoted: 8 Post(s)
If you have a compatible code reader you can read the code, or, when you first start the truck the air bag light will flash a two digit code. It will do this twice then light continuous. Mine just started doing it. The air bag light for the passenger shut off switch is blown out and is throwing a 27 code on the dash. If it is the same with yours, check to see if the air bag light on the passenger shut off switch is lighting up when first starting.
01 F250 XL Ex Cab: RIP 12-15-2013
1999 F250 XLT 4X4 auto, Bully Dog 5" straight pipe, rest stock.
Solid98 is offline
post #3 of 6 Old 06-27-2014, 10:46 AM Thread Starter
I may be in the wrong place, my truck was built in march 98 and I have not seen a passenger shut off switch.
Thanks
llesg is offline
post #4 of 6 Old 06-27-2014, 11:46 AM
Solid98's Avatar
Quoted: 8 Post(s)
Is yours a super duty or light duty? Have you checked for any flashing light codes? What body style do you have? Reg cab, super cab, crew cab?
Solid98 is offline
post #5 of 6 Old 06-27-2014, 04:52 PM
Joel's Avatar
Quoted: 10 Post(s)
I took a small pc of black electrical tape and covered the light. Problem solved
I'd have to be hit by something pretty darn big to need airbags
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #6 of 6 Old 06-30-2014, 04:52 PM Thread Starter
1999 air bag light
Funny thing , I went out to check the flash code and It didn't flash.
Drove down to a buddies house to check with his scan tool and there were no codes and..... the light stopped coming on????
Let sleepy Dogs lie I always say!!!
It's a super duty crew cab with 8" lift
llesg is offline
