Hissing Noise - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-15-2009, 05:09 PM Thread Starter
Hissing Noise
I have done some mods -- including a 4 inch TB exhaust and a DP chip. Now that it is cold out (10 degrees right now) not only can I hear the turbo whine -- but I also hear what I think is the waste-gate hissing -- until it warms up (like 3 or 4 miles of driving). Is this normal? Was this happening before but I just couldn't hear it?
2000 Excursion 7.3 psd
80,000 Miles
PowerSlot Cryo Rotors + Hawk Pads
Edelbrock Performer IAS Shocks
Diamond Eye 4" Turbo back exhaust
DP Tuner F6 chip with 60HP tow, 80HP Econ and Decel Tunes
Boost, EGT and Trans Temp gauges on pillar
K&N air filter in stock system
Pull Rite towing system
6.0 Trans Cooler
redoil is offline
post #2 of 10 Old 01-15-2009, 05:10 PM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
Thats your EBPV staying shut to warm up your truck. They suck and no one seems to like them!
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #3 of 10 Old 01-15-2009, 05:10 PM
PMR = JUNK
Jake's Avatar
Quoted: 5 Post(s)
Its not the wastegate, you never hear that. What you are hearing is the EBPV, Exhaust Back Pressure Valve. Its a butterfly valve in the exhaust right after the outlet of the turbo that closes when the engine is cold to aid in warmup. Also makes a nice exhaust brake with some wiring.
BPS President
2000 F-250, forged rods, 38r turbo, BTS trans, hutch mod, TW tuning and Bad Night Special 50 horse Caterpillar injectors
Originally Posted by alberta 7.3 View Post
Yeah, I'd probably feel a bit drained after firing twice in rapid succession.
Jake is offline
post #4 of 10 Old 01-15-2009, 05:11 PM
PMR = JUNK
Jake's Avatar
Quoted: 5 Post(s)
I like mine.
BPS President
Jake is offline
post #5 of 10 Old 01-15-2009, 05:13 PM
Quoted: 6 Post(s)
Originally Posted by cob32187 View Post
I like mine.
I stand corrected.
Do you have a link or a write up on how to do the exhaust break mod?
post #6 of 10 Old 01-15-2009, 05:16 PM
PMR = JUNK
Jake's Avatar
Quoted: 5 Post(s)
Yeah, i actually drew up a schematic for it. Im not sure if it's in the tech files or not. If you want it i can give you a copy of it though.
BPS President
Jake is offline
post #7 of 10 Old 01-16-2009, 02:27 PM
Midwestern4x4's Avatar
Send a message via AIM to Midwestern4x4 Send a message via Yahoo to Midwestern4x4
Got a link?
I was looking at the Dfuser kit , they seem to be nice but how well does it work for an exhaust brake? Is the Converterlock required?
~Philip
99 F250 Ext Cab Long Bed. 7.3 4x4 5.5 " Fabtech Lift.
Gooseneck , Straight Pipe, Intake , DP F6 , And other goodies...
Supporting the Midwest
Midwestern4x4 is offline
post #8 of 10 Old 01-16-2009, 02:35 PM
CompressionIgnitionAddict
99ildually's Avatar
I liked mine till the accuator started to leak.
-Josh
Early 99 F-350 2wd DRW
6 Speed 4.10 rear
4 in turbo back muff delete
Intake Superchip & 4k mod
99ildually is offline
post #9 of 10 Old 01-18-2009, 03:19 PM
PMR = JUNK
Jake's Avatar
Quoted: 5 Post(s)
Originally Posted by Midwestern4x4 View Post
Got a link?
Works pretty good. If you don't have tuning that keeps the TC locked when you push the brake, you will need to wire up a lockup switch too.
BPS President
Jake is offline
post #10 of 10 Old 01-18-2009, 04:07 PM
tturbonegro's Avatar
i hated and unpluged my EBPV. i have TB 4" as well...no muff. no res....once it got cold mine would do it..very loud and annoying...there is a small plug right by the turbo..pull it out and tuck it in somewhere out of the way..and then just let the truck warm up a little longer when cold...
tturbonegro is offline
