Hvac problems defrost for any setting only - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-24-2014, 07:17 PM Thread Starter
Hello all, my 03 f-350 crew cab 7.3 is only putting ac and heat through the defrost. I know there is a leak somewhere but I'm having a hard time finding where. I know my fuses are all good, the vacuum pump works but runs constantly, it had auto hubs but swapped them to manual hubs. Now there is a large cannister behind my battery on passenger side that has two lines of the pump going to it. If it take the plug of that holds both lines, if I plug the line closest to fire wall I think it goes to a black line next to a red line, the pump gets vacuum and turns off. It looks like this : where could the line that's leaking be? Thank you all.
Firemanpowerstroke2003 is offline
post #2 of 5 Old 06-24-2014, 07:30 PM
Joel's Avatar
Quoted: 10 Post(s)
When converted the hubs did you remove and cap any related lines?
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 5 Old 06-24-2014, 07:39 PM Thread Starter
Yes and this problem didn't start till this year a couple years after swap
post #4 of 5 Old 06-24-2014, 07:59 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Check this thread out....
Vacuum Lines?
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #5 of 5 Old 06-24-2014, 08:13 PM Thread Starter
Thank you! I did notice that solenoid that it had lines comin out if it but I didn't unplug it because I was having a hard time getting the plug out with everything else in the way. I will try unplugging it and plugging the feed line when I tear into it again
