What is this sensor? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-24-2014, 04:28 PM Thread Starter
2002 F350 7.3l Found this sensor hanging out behind my cold air intake box. Not sure what it is but I am thinking it is a temperature probe.
If so, does the computer use this for fuel/air ratios or is this just for outside air temp readout for the cab display?
Mike
Tripspike is offline
post #2 of 6 Old 06-24-2014, 06:18 PM
Joel's Avatar
Quoted: 10 Post(s)
That is the intake air temperature sensor.
It's pretty much useless. I relocated mine to the front bumper and it now acts as my outside temperature on the edge insight.
It's surprisingly accurate.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 6 Old 06-24-2014, 07:56 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 21 Post(s)
Feedback Score: 12 reviews
I read awhile back it communicates with the PCM and the glow plugs.. Can't remember the specifics but serving along those lines.
Sent from AutoGuide.com App
2017 f250 platinum
Deleted at 8k miles.. trying to be patient waiting for custom tunes...
mts678 is offline
post #4 of 6 Old 06-24-2014, 09:04 PM
Joel's Avatar
Quoted: 10 Post(s)
Exactly. When you're starting the truck anyways, aka using glow plugs, the air intake sensor can be anywhere and it makes no difference. Win win
Joel is offline
post #5 of 6 Old 06-24-2014, 10:26 PM
DIMBLEWAMBIE's Avatar
That is pretty genius, hopefully the torque app monitors that sensor? if it does i will definitely move mine to monitor outside air temp when i get it. Smart thinking
Justin DIMBLEWAMBIE Lamb
2002 F250 7.3l 4x4 CCLB
8in lift Deaver springs, Bilstein 5125s & 5160s
Toyo 37x13.50r17 MTs, Eagle Alloy 185s
F8 Destiny DP-Tuner & Dyno Proven
Banks Boost, EGT, Trans gauges
Banks straight pipe, K&N intake w/ 6637 filter
Banks EBPV-less elbow, Wastegate ON [OFF]
Foil delete mod, Zoodad mod
11" LED bar, 05-07 grill
DIMBLEWAMBIE is offline
post #6 of 6 Old 06-25-2014, 01:43 PM
Vannnce's Avatar
Quoted: 13 Post(s)
^^it does. i Just messed with mine the other day to see the effects of the zoodad mod
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
