Hard start when hot - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Joel
post #1 of 4 Old 06-24-2014, 03:57 PM Thread Starter
BrodieBiking's Avatar
Hard start when hot
Truck has been acting weird ever sense i installed bigger injectors.
It starts beautifully in the mornings, but if i drive it 30+ minutes turn the truck off and try to restart it takes a good 10 seconds for it to get going. When it cranks its the motor is firing but it takes a while for it to catch.
My guess is weak hpop sense the glow plugs aren't on when the truck is hot?
I should mention that the truck does have just under 400,000km and has a crazy amount of blow by coming out of both valve covers, so could it possibly be low compression?
2002 F350 CCLB DRW
ZF6 SWAPPED!
--Southbend 1944-6OFEK
12.5in lift on 24.5's----------3" Body Lift
MBRP Dual 4"--------------Muffler Delete
K&N Intake----------------AFE Spider
Garret GTP38R BB--------- P.I.S. billet wheel
TS 6pos chip--------------NLTD tunes
P.I.S. 200cc/80%--------- P.I.S. IDM
Parrot Asteroid-------Boston Accoustic SR80's
NVX VCW 10s------------ McIntosh MC431
Warn Manual hubs---------Bed Rails/Air tank
BrodieBiking is offline
post #2 of 4 Old 06-24-2014, 04:12 PM
Joel's Avatar
Quoted: 10 Post(s)
What oil are you using? Is it due for a change?
It's definitely an ICP related issue. Could be the IPR, hpop, one injector just not quite seated right, or the oil itself
Jmndz38 likes this.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 4 Old 06-24-2014, 04:22 PM Thread Starter
Rotella T, Just changed 700km's ago.
I do have an AE scanner, what kind of numbers should i be looking at?
I guess i could unplug the ICP connector while running, and if there is no change that would tell me that the sensor is bad?
2002 F350 CCLB DRW
ZF6 SWAPPED!
post #4 of 4 Old 06-24-2014, 06:23 PM
Joel's Avatar
Quoted: 10 Post(s)
To be clear, I don't think the ICP sensor is necessarily the issue. Just something to do with the high pressure oil system.
I'd imagine that it's just taking that whole 10seconds to build 500icp to start.
The oil is thinner when it's nice and hot, and is able to sneak through whatever tolerances easier.
It's a hard one to chase down.
About 6 weeks and many miles after I installed my injectors I had an oring blow out. It was installer error.
Joel is offline
