electronic problem - Ford Powerstroke Diesel Forum
Old 01-15-2009, 06:48 AM
Send a message via MSN to geoff thomas
Question electronic problem
The lights on the top of my cab all have bulbs in and when you flip the switch to turn them on the led on the switch lights up but the lights on the cab dont come on, they have never worked since i got the truck any ideas?
Old 01-15-2009, 06:52 AM
Sounds like they were added after the fact. Your gonna have to trace the wires from the switch and see what is going on. Make sure you have power and ground there first which you should since the light is coming on...
Old 01-15-2009, 06:56 AM
yeah there is power and ground should i possibly be looking for a fuse? in the main fuse box? or are they wired in series through the roof so if 1 bulb is gone nothing works like a christmas tree???
Old 01-15-2009, 07:05 AM
If the fuse was blown you wouldn't have power anywhere.
I'm not sure about the wiring being in series. Never thought about that before....
Take the lens cap off of the lights and check for power and ground at all of those and that will tell you..
Old 01-15-2009, 07:18 AM
I am i total idiot sorry the switch ithought it was actually powers the rear fog lamp!!! oops i am no good at this mechanic stuff!!
I understand that they should come on when i turn my headlamps on is that right? if so that does not work either!
any help now?
sorry again
Geoff
Old 01-15-2009, 07:40 AM
LOL. They should come on when your parking lights come on. If your parking lights are on then I would pull the covers off the cab lights and check for power and ground at each of those.
Old 01-15-2009, 08:38 AM
How do i check for those? i am really a techno idiot!!!
Old 01-15-2009, 08:48 AM
Your parking lights are the orange colored lights in the front. They come on with the first click of the light switch and also stay on when the headlights are on. The first click turns all parking lights on and the second click turns headlights and parking lights on. Does that help?
Old 01-15-2009, 09:05 AM
Still no luck i think i am gonna have to run her into an electrics shop thanks for the advice tho i think i am just not cut out to be an electrician!!!!
Geoff
Old 01-15-2009, 09:16 AM
so your parking lights are not coming on??? If so you need to check fuses. Look in the owners manual and see which one is for the parking lights...
