2002 7.3 lifespan expectations???? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 01-15-2009, 05:08 AM Thread Starter
slayerf250's Avatar
have been getting a little curious about what to expect in the not so distant future with regards to my engine....
Right now I am at 172,000 miles, completely stock, oil changed between 5k & 7k miles, new air and fuel filter evry 3rd oil change....
only issues with truck have been:
1 starter replaced
1 altenator rebuilt
1 CPS replaced
1 GPR relay replaced
other than that, never had a wrench on her,,,,never found a boot loose or anything....and even with winter blend I can average between 15 & 17 MPG.
correct me if I'm wrong, but a noticable decrease in MPG's is a sign that something is not working correctly in the compression ignition engines, so as long as my MPG's stay the same, I can assume everything internal and external on the engine is working as it should.....
How far can these engines go before they are just "WORE SLAP OUT"
2002 F-250 Lariet/4x4/7.3L/auto tranny/Crew Cab/SWB/3.73 gears
Bone stock (for now)
slayerf250 is offline
post #2 of 12 Old 01-15-2009, 05:16 AM
szyd's Avatar
I don't think you will find that answer. As long as all fluids are changed as well as filters religiously you will get a lot of service out of that truck. There are guys on here that have bought trucks with almost 200k and are starting to mod them.
Dale
99.5 F 350 Totaled
2000 F350 Lariate
CC
SB
4x4
4" turbo back
cold air. Zoodad
Banks big head
Wicked wheel
4" BDS lift. With Bilstein's
all brought together by TW
szyd is offline
post #3 of 12 Old 01-15-2009, 08:16 AM
PowerStroker007's Avatar
Send a message via AIM to PowerStroker007 Send a message via Yahoo to PowerStroker007
well if they last then i have a lot of life left in mine but of corse its a so thats why
Just Bought it
7.3 6 spd. man. 70,000 miles banks 4 inch exhuast edge chip
soon to come-
Stage 1 injectors ball bearing turbo and ts 6 position chip
new paint new tires and rims 4 inch lift and some more gauges and foil delete
PowerStroker007 is offline
post #4 of 12 Old 01-15-2009, 08:19 AM
Ole White
bigwhite7.3stroker's Avatar
If you maintain it properly it will 300K + some on here with 400-500K still running good
Looking for 05-07 front end with Harley Lights
bigwhite7.3stroker is offline
post #5 of 12 Old 01-15-2009, 08:26 AM
jetskier2313's Avatar
Send a message via AIM to jetskier2313
I got 245,000 and still moding it. I think it all depends on how you drive it!
2001 Ford Excursion Limited
DIY Intake
Foil Delete
Headlight/Foglight mod
10k Mod
Gauges
Dual Fire/Ice Led Bar in the Rear
Led front
HID Projector Headlights and LED Fogs
TW 6pos Chip (Stock, Eco, tow, extreme, race, smoke) :burnout
2400watts of bass in the back
EBPV Manual switch!!!
455000 on the clock and counting
jetskier2313 is offline
post #6 of 12 Old 01-15-2009, 08:41 AM
Ole White
211,000 here and still modding have Stg II's and fixing to put Stg III Injectors in and shes still running great
post #7 of 12 Old 01-15-2009, 09:06 AM
Plenty to go...
My 1999 7.3PSD had 200,000 on it when I bought it in 06. It was a fleet truck, pulling a bobcat trailer all of its life. It got a new tranny at 185xxx, before I got it. I have put a fuel pump, ball joints, rear main seal on it. I expect a few things to need replaced, but I plan to get 500xxx out of it. I was able to talk to the fleet mech. where it lived before me. He had no reason to lie to me since I bought it third hand. He offered me the maint records for it. It got 3-5k pm its whole life. It was stock until I put a 70hp chip in it. Next is the cosmetic stuff, its kind of a sleeper. Sure does run good though. I do 5k pm without fail. Good oil, good filter, KN air intake kit that gets regular clean/oil. Living a clean life makes a long life. If I have any other tranny problems, it is gonna get a 6spd man. Just for fun...
cblackwell373 is offline
post #8 of 12 Old 01-15-2009, 02:25 PM
mnstroker's Avatar
Just flipped 270,000 and soon too have big oil
10,000 Lakes ORG Chapter Member
01 F350 CREW CAB LONG BOX 4X4
DIY INTAKE
AUTOMETER BOOST PYRO AND TRANS ON THE PILLAR
ZOODAD
WICKED WHEEL
STRAIGHT PIPED
AIH DELETE
CCV MOD
EBPV DELETE
ADRENALINE HPOP
STAGE 2'S
FUEL SYSTEM
mnstroker is offline
post #9 of 12 Old 01-15-2009, 02:34 PM
Ole White
Do you have PMR's or Forged rods??
post #10 of 12 Old 01-15-2009, 02:43 PM
mnstroker's Avatar
PMRS i assume Theres an off chance they could be forged though
DIY INTAKE
ZOODAD
WICKED WHEEL
STRAIGHT PIPED
AIH DELETE
CCV MOD
EBPV DELETE
ADRENALINE HPOP
STAGE 2'S
FUEL SYSTEM
