No voltage at trailer hook up....help - Ford Powerstroke Diesel Forum
post #1 of 18 Old 06-24-2014, 10:02 AM Thread Starter
My trailer hookup connector (4-pin type) does not have any voltage output other than the brake light. I measured voltage and all three female pins read 0.02V.
I checked fuse No.13 (trailer hookup) in the fuse box and it was ok....
I use a motor tool to clean the pins on both truck and trailer connectors, no luck...
The truck running light, back up light, blinkers, brakes all work good.
What should I look into? This is a 2000 F250 7.3L
Thanks for your advice
mas360 is offline
post #2 of 18 Old 06-24-2014, 11:58 AM
BrodieBiking's Avatar
Check for power at the trailer harness while pressing on the brake.
Sent from AutoGuide.com App
2002 F350 CCLB DRW
ZF6 SWAPPED!
--Southbend 1944-6OFEK
12.5in lift on 24.5's----------3" Body Lift
MBRP Dual 4"--------------Muffler Delete
K&N Intake----------------AFE Spider
Garret GTP38R BB--------- P.I.S. billet wheel
TS 6pos chip--------------NLTD tunes
P.I.S. 200cc/80%--------- P.I.S. IDM
Parrot Asteroid-------Boston Accoustic SR80's
NVX VCW 10s------------ McIntosh MC431
Warn Manual hubs---------Bed Rails/Air tank
BrodieBiking is offline
post #3 of 18 Old 06-24-2014, 12:12 PM
Joel's Avatar
Quoted: 10 Post(s)
I could be mistaken, but I'm pretty sure there are two fuses relevant to the trailer lights on my truck.
Check more fuses. And if that's not it you probably have a short somewhere, so just redoing the wiring and tying into the tail light harnesses would be easiest
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #4 of 18 Old 06-24-2014, 12:17 PM Thread Starter
The brake light pin was the only one with voltage output. The problem is with the running light and turn signals.
mas360 is offline
post #5 of 18 Old 06-24-2014, 12:18 PM Thread Starter
I checked all fuses and none was bad.
mas360 is offline
post #6 of 18 Old 06-24-2014, 12:28 PM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
Huh. Here is a pic. Which wire had power. Did you check power with the parking lights on? Flashers?
Attachment 303841where did you ground to?
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #7 of 18 Old 06-24-2014, 12:33 PM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
My 4 pin connector went bad years ago and I cut it off. Now I use this. Attachment 303849its a 4pin to 7 pin adaptor
01 f-250, Standard
post #8 of 18 Old 06-24-2014, 12:37 PM Thread Starter
The middle pin is the one with power when the brake is pressed. The other two had voltage reading 0.02V. I ground the multimeter black probe to the covered pin (ground pin).
Yes, I checked flashers and they were dead. I checked all light bulbs and out of four bulbs three of them were bad.
No, I did not have parking lights on.
I also tried with the 4-pin to 7-pin adapter and the result was exactly same. That tells me the problem is likely upstream, not in the bundle.
By the way this is a boat trailer.
mas360 is offline
post #9 of 18 Old 06-24-2014, 12:49 PM
Airborne CIB's Avatar
When I bought my truck (2005) it had same issue, 0.02v If the 7.3 is different, then ignore this post.
Like was said in previous post, there are additional fuses and relays which are under the hood. They are in place to protect the truck lights if a trailer has a shorts or bad grounds. it sounds like you have at least a relay and a fuse blown. after you fix the fuses, be sure to check your boat trailer wiring harness, fuses dont blow for no reason
Glendale, AZ
'05 F250 XL Extended Cab - 2 Wheel Drive, No Options Except: Integrated Brake Controller, 3.73 w/ Limited Slip, Upfittter Switches & AC
Added: Edge Monitor with EGT, Fuel Pressure, coolant pressure, low oil pressure system sensor & Ambient Temperature Sensors, turbo timer & back up camera. High Idle Mod. Manual Fan Mod, Power fold/power extend mirrors.
Installed: Cruise Control w/ Leather Steering Wheel, 17 Alloy Rims off XLT, 40 20 40 Vinyl Front Seats
Well maintained with Motorcraft parts, over 222k miles and still have original head bolts.
Airborne CIB is offline
post #10 of 18 Old 06-24-2014, 12:50 PM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
The trailer plug fuses under the hood. Your getting power to your left side but not your right that's most likely a fuse under the hood. Turn the park lights on and check the one next to the ground. Easy way to check a fuse is to put your black lead to the batt and touch each side of the fuse while it's plugged in and the key is on. If you don't get power on both sides of the fuse it bad.
01 f-250, Standard
