4" lift what do I need - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-23-2014, 09:17 PM Thread Starter
01 Ford F350. I want to install 4" pro comp springs front and rear with bilstien 5100 shocks what else do I need? Any drop brackets? Spacer on the carrier bearing?
Mtn.Tamer is offline
post #2 of 10 Old 06-24-2014, 05:49 AM
03ranger30's Avatar
I would think an adjustable track bar, new shocks. I am not sure about the carrier bearing.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #3 of 10 Old 06-24-2014, 07:47 AM
Joel's Avatar
Quoted: 10 Post(s)
Drop pitman arm too
Any reason you don't want to just buy a kit?
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #4 of 10 Old 06-24-2014, 08:16 AM
sbluke55's Avatar
Quoted: 622 Post(s)
Garage
Drop pitman arm, drop track bar bracket, drop sway bar end link brackets, brake line relocation tabs or longer brake lines. Carrier bearing shims.
Buy a kit, it much easier.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #5 of 10 Old 06-24-2014, 10:10 AM Thread Starter
The main reason is so I could up grade to the bilstien shocks. But maybe summit racing will let me build a kit
post #6 of 10 Old 06-24-2014, 10:42 AM
sbluke55's Avatar
Quoted: 622 Post(s)
Garage
If you want to run bilsteins they make them for stock trucks. They are valved for the truck. They are just not the 5100 series. If you want to lift your truck go ahead. If you want to lift it just to run 5100 I think your money could go into a better shock for stock ride height.
01 f-250, Standard
sbluke55 is offline
post #7 of 10 Old 06-24-2014, 11:00 AM
sbluke55's Avatar
Quoted: 622 Post(s)
Garage
Never mind my lost post. I'm an idiot. Proceed.
01 f-250, Standard
sbluke55 is offline
post #8 of 10 Old 06-25-2014, 04:52 PM Thread Starter
I have been wanting to install a 4" lift for awhile. My springs have 200k on them and when I stop or take off I feel a thud. When I watch my springs on take off they allow the axle to roll so much that my over loads hit the stops, and thats with a soft take off. So I would guess week or broke springs? So may be its time for the lift. I keep hearing how good the bilstien shocks are? My friend has the same truck with lift and rancho 9000 adjustable shocks and he loves them what do u recommend?
post #9 of 10 Old 06-25-2014, 06:28 PM
sbluke55's Avatar
Quoted: 622 Post(s)
Garage
What's the budget? Do you tow? What do you use the truck for? Lift kits range from $800-$5000
01 f-250, Standard
sbluke55 is offline
post #10 of 10 Old 06-25-2014, 08:29 PM Thread Starter
Its just a driver on rough paved roads. I dont tow much. I would like to keep it under 900-1000
