Gear question?? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-23-2014, 03:53 PM Thread Starter
Ford Cowboy's Avatar
Quoted: 5 Post(s)
Gear question??
Truck in sig. 3.73 stock gears. Been Rollin around on the new 315's for the last month. Noticed that is pretty sluggish getting up to speed on the highway. Also noticed it downshifts more than it used to. I had the speedo recalibrated for the 315's. Speed seems right on (or close to it). I can do 75mph at 2k rpm that's kinda cool. If I keep it at 2k rpm it will blow right over most of the hills without downshifting. It would be nice to not have to keep my foot in it just to keep from downshifting. My question, would going up to 4.10 gears help with the downshifting and also give a little more ummmph when I put my foot in it?? Thanks for any help or suggestions.
Ford Cowboy is offline
post #2 of 12 Old 06-23-2014, 07:00 PM
Had 3.73s in my 250 with 315s and ran a dp tuner. I never saw much perceived power loss and it would pull hell off the hinges. Could it be that you are expecting to much?
I have a dually now with 4.10s and i like the 4.10 ratio but 65mph is about as hard as I'll run it.
tech701 is offline
post #3 of 12 Old 06-23-2014, 07:24 PM
natemoses13's Avatar
3.73's seem to be what almost everyone wants. Good combo for mileage and towing.
E99 F350 crew cab dually flatbed. 2wd 6-speed. Boost and egt gauges. 6637 intake. Superchips flashpaq.
L99 F350 crew cab dually flatbed. 2wd Auto. Billet TC & aux cooler. 6637 intake. Superchips flashpaq.
natemoses13 is offline
post #4 of 12 Old 06-23-2014, 07:48 PM Thread Starter
Quoted: 5 Post(s)
Yeah that very we'll could be it. I think a tuner might help it some. Kinda wake it up a little. The downshifting really isn't bad, it's just something different.
cummin is the mess left behind by strokin!!
2000 7.3l f350 4x4 cclb psd. 4r100 trans.Ranchhand everything! 6637 intake, zoodad mod, custom big rig runnin lights, ccv mod, RR boots and plenum inserts, foil delete, EV2 gauges, edge cts, tuff country 2.5" leveling kit, X codes, 315/75r16 coopers, 08 mirrors, 6.0 trans cooler, tgc dual steering stabilizer, fabtech adj. trac bar, mbrp 5" turbo back straight pipe with 8" tip, php 6pos, ssbc brakes, ebpv delete, cat elc 100,xxx
post #5 of 12 Old 06-24-2014, 04:30 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
I have 3.73's in my srw 250 with 35's and 4.10's in my stock tired dually... drive the 250 daily, dp tuner on 80 hp econo and its fine. Switch to stock and its a dog. 4.10's would be nice but it works as-is. Dually would be fine with higher gears on the stock tires.
OP: tune it... cheaper than gears.
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #6 of 12 Old 06-24-2014, 05:59 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
You don't have a sig
Custom tuning would help and is much cheaper then a gear swap
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 12 Old 06-24-2014, 06:14 AM
ZackMicF's Avatar
Quoted: 29 Post(s)
yeah im with these guys! throw a nice tuner in there, im running 38x15.5r20 on my stock 3.73 gears, and with my chip i can still haul *** and get 20mpg on a 8" lift
i like the stock gears because i do lots of road trips, and i can do 80-90mph for long periods of time without the RPMs being too high unlike a stock setup at that speed would have the turbo boosting the whole time
but my vote goes to a good tuner, S&B Intake and 4" straight pipe, that should really help
01 F250 7.3 CC SB 4X4 THE MOST BADASS 7.3L AROUND!!! too many parts to to list!! wont fit in the Sig. Block!!! but check out the build thread, well worth the time
BUILD THREAD^
ZackMicF is offline
post #8 of 12 Old 06-25-2014, 01:18 PM
"im running 38x15.5r20 on my stock 3.73 gears, and with my chip i can still haul *** and get 20mpg on a 8" lift"
20mpg you say? Please say what chip you have so that i might worship it!!!!
Sorry son.... but I call toro do do on that one.
tech701 is offline
post #9 of 12 Old 06-25-2014, 01:48 PM
ZackMicF's Avatar
Quoted: 29 Post(s)
i get 20mpg at 65mph, i normally do 75-80mph and get 17 to 18mpg at that, and at 90-100 i get 12 which really sucks but i be hauling ***,
but if i do baby her the tan last forever!!!!!
i have the Banks Big Hoss Chip but i just bought the TS 6 pos. Chip so well see how well this one does
BUILD THREAD^
ZackMicF is offline
post #10 of 12 Old 06-25-2014, 04:04 PM Thread Starter
Quoted: 5 Post(s)
That's weird, I had one the other day . Been lookin at a 6 position switch with beans tunes. What do y'all think about beans? I've always been concerned about adding a tuner. Worried I'm gonna hurt, strain, blow the engine. Wear $hit out faster. Thoughts?? My truck currently has 93,436 miles. Oil and filter changed every 2k since birth along with fuel filter every 4k. I try to maintain the engine as best I can to keep it healthy.
