Front shock removal/replacement - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-23-2014, 09:09 AM Thread Starter
McKinneyMike's Avatar
I am going to replace all 4 of my shocks, but I was looking at the way that the front shocks mount and was wondering what tools were needed to get to the nut on the top of front shocks? I know that I have to hold the very top captive with a crescent or other wrench to keep it from spinning when loosening the nut, but I am not sure what wrench I would need to get to the top nut as nut is in a well if you will looking from the outside looking in towards the mount from the wheel well. What is the best wrench/method of getting this nut loosened.
Will this work? I hope so as I just bought it
Lisle Shock Absorber Tool
http://www.amazon.com/Lisle-20400-Universal-Shock-Absorber/dp/B000CO88C6
2000 F250 SD 2WD 7.3L
RiffRaff billet compressor wheel
PHP Hydra
4" Diamond Eye, turbo back w/5" tip
ISSPRO EV2 Pyro, Trans Temp, Boost and Fuel Press
Kenwood Exelon/Focal/Image Dynamics/PPI
McKinneyMike is offline
post #2 of 6 Old 06-23-2014, 01:01 PM
Wyofordpower's Avatar
Quoted: 2 Post(s)
I just did all four shocks on my truck yesterday. The top should just be an 18mm nut. I didn't need any special tools, just a socket and ratchet along with some wd-40 penetrating spray.
Wyofordpower is offline
post #3 of 6 Old 06-23-2014, 01:05 PM
sbluke55's Avatar
Quoted: 591 Post(s)
Garage
He is 2x4. You have a 4x4. I use gear wrenches. But two regular wrenches will work but takes a while. Wd-40 every nut and bolt a few time a day or so before the job starts. I've also used vice grips on the shaft only on the old on tho.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 6 Old 06-23-2014, 01:07 PM
Quoted: 2 Post(s)
Ahh okay that makes more sense. I can't see sigs and whatnot on my phone. Sorry
post #5 of 6 Old 06-23-2014, 01:10 PM
Wirer brush the threads if rusted also helps, then use penetrant spray.
letitsno is offline
post #6 of 6 Old 06-23-2014, 01:40 PM Thread Starter
I have applied Kroil to all nuts. I ordered the Lile shock absorber tool as it looks like it will make the job a little easier. Back shocks look to be pretty easy. Just drop the back tire to get easier access. I am not a gear head, but I am trying to do more of my own work when I feel that I can these days.
Thanks for the tips. I will hit the bolts with the Kroil a few more times before the weekend.
PHP Hydra
