Steering wheel play - Ford Powerstroke Diesel Forum
post #1 of 13 Old 06-22-2014, 01:14 PM Thread Starter
Steering wheel play
hey guys, just recently purchased an 01 excursion 7.3 turbo diesel (and I love it). The only thing that appears to be problematic so far is there is quite a bit of play in the steering wheel and it varies from side to side , just feels like its not grabbing for the first couple inches of turning then it starts to steer.
Any ideas/suggestions would be greatly appreciated. thanks!
http://www.autozone.com/autozone/par.../N-jfaozZ8oxw7
wild guess, but is this my fix?
amerimuscle is offline
post #2 of 13 Old 06-22-2014, 02:53 PM
DIMBLEWAMBIE's Avatar
Likely just the pitman arm, have someone crawl under there while you steer back and forth and see if there is some play there or anywhere else. If it does turn out to be a box issue, I would rather send out my ford unit to get rebuilt VS an aftermarket offering. Thats what I did when I first got my truck as it was leaking.
Justin DIMBLEWAMBIE Lamb
2002 F250 7.3l 4x4 CCLB
8in lift Deaver springs, Bilstein 5125s & 5160s
Toyo 37x13.50r17 MTs, Eagle Alloy 185s
F8 Destiny DP-Tuner & Dyno Proven
Banks Boost, EGT, Trans gauges
Banks straight pipe, K&N intake w/ 6637 filter
Banks EBPV-less elbow, Wastegate ON [OFF]
Foil delete mod, Zoodad mod
11" LED bar, 05-07 grill
DIMBLEWAMBIE is offline
post #3 of 13 Old 06-22-2014, 03:20 PM
sbluke55's Avatar
Quoted: 571 Post(s)
Garage
Check all the tie rod ends, track bar , and ball joints first. Then if all of those check out its the steering box. If you do need a steering box I recommend red head.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #4 of 13 Old 06-22-2014, 05:40 PM Thread Starter
Greatly appreciated guys. Anyone else care to chime in
post #5 of 13 Old 06-22-2014, 05:48 PM Thread Starter
As for the rebuild vs aftermarket.... there's a core charge for the one I looked at so I presume they are just factory rebuilds?
post #6 of 13 Old 06-22-2014, 05:59 PM
99bft's Avatar
Yes they are just remaned ford units. most of which are remaned by A1 Cardon since the own majority of the reman auto parts world. The only way you can get away from them is to find someone local to you that can properly rebuild it or send it off to Redhead to be upgraded.
99.5 F350 CREW CAB DUALLY 4X4, 4:10 (LS),ZF6 SWAPPED, RANCHO 2.5"LIFT, 305/70/16 NITTOS, RHINO LINED, B&W TURN OVER, TEKONSHA PRODIGY P3, MBRP 4" TURBO BACK, K&N CAI, PHP Hydra, Riffraff AIH DELETE, BILLET COMPRESSOR WHEEL, HPX,& "OCR", NON EBPV PEDESTAL, HIGH FLOW EXHAUST HOUSING, FOIL DELETE, ZOODAD, ISSPRO EV2 GAUGES, 6.0 TRANNY COOLER, EXTRA QUART POLISHED DIFF COVER, WARN HUBS, ARROWCRAFT SPACERS, ALPINE TOUCH SCREEN
OTHER TOYS:
65 N600 390
67 N1000 220 CUMMINS
99bft is offline
post #7 of 13 Old 06-23-2014, 08:03 AM Thread Starter
Is there a way to adjust it somehow ? Trying to avoid replacing the box if unnecessary
post #8 of 13 Old 06-23-2014, 08:08 AM
sbluke55's Avatar
Quoted: 571 Post(s)
Garage
You can adjust it but it only helps a little while. On top of your box there is a nut with a bolt running threw it that has a place to put an Allen wrench. Loosen the nut and tighten the bolt 1/4 turn then tighten the nut. Then take it for a spin.
01 f-250, Standard
post #9 of 13 Old 06-23-2014, 04:04 PM
99bft's Avatar
I agree it only helps for a little while. From my numerous experiences its just a short term fix on a box thats already heading south. All you're doing is remeshing some wore out parts.
OTHER TOYS:
65 N600 390
99bft is offline
post #10 of 13 Old 06-23-2014, 04:14 PM Thread Starter
ok so odds are its the box? I did some more investigating today.... any thoughts on the damper behind the pitman arm ? could that be shot?
