turbo question - Ford Powerstroke Diesel Forum
Old 01-14-2009, 08:32 AM
turbo question
I have an early 99 powerstroke 6 speed dually truck with an edge evo chip. on the highest setting im only seeing around 19psi. For mods I have opened up exhaust and cold air intake. Im thinking I must have a boost leak? 19psi seems low. what do you guys think?
Old 01-14-2009, 08:38 AM
Illiana Chapter Director
That's about right. Stock is only around 16 psi.
Old 01-14-2009, 08:39 AM
i think you have a boost leak....
Old 01-14-2009, 08:50 AM
how do you test for boost leaks
Old 01-14-2009, 08:57 AM
BOB at dieselsite makes this : http://www.dieselsite.com/index.asp?...ROD&ProdID=669
you can use that to check for boost leaks
-Raul
Old 01-14-2009, 09:46 AM
the pipe that comes up from my manifold to my turbo I noticed has some black soot where it connects to the up pipe. would this cause me to loose boost?
Old 01-14-2009, 10:29 AM
If you have an exhaust leak before the turbo that could present a problem. It wouldn't be a boost leak but it would keep the turbo from spooling.
Old 01-14-2009, 10:31 AM
Wow I just posted an hour in the future.
Old 01-14-2009, 06:42 PM
hmm thanks for the info, if it wasnt so bitter cold here in north east pa id be out there workin on it.
