My Headlight Swap - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 22 Old 06-21-2014, 10:09 PM Thread Starter
My Headlight Swap
Thought I'd do the headlight swap. Wasn't too hard. But the new headlights only go in tweaked as you can see. I had t cut off a piece of plastic on both sides to square them up. Now they are jus fine.
ID:	302617   Click image for larger version
ID:	302625   Click image for larger version
Krazymaan is offline
The Following User Says Thank You to Krazymaan For This Useful Post:
StrokinAlaska (07-27-2014)
post #2 of 22 Old 06-22-2014, 02:02 AM
ZackMicF's Avatar
Quoted: 29 Post(s)
probably went in tweaked because they look like chinese ebay lights. but good job fixing that up,
i went with the OEM 07 harley lights on mine and they went in straight with no modding
john galt likes this.
01 F250 7.3 CC SB 4X4 THE MOST BADASS 7.3L AROUND!!! too many parts to to list!! wont fit in the Sig. Block!!! but check out the build thread, well worth the time
BUILD THREAD^
ZackMicF is offline
post #3 of 22 Old 06-22-2014, 05:54 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Looks great, I need to find a set for mine Kause the oem ones are just haggard
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 22 Old 06-22-2014, 05:59 AM
BryceB's Avatar
I'm thinking about doing a set of '03 lights on mine. Keep the turn signal/paring light assembly and just replacing the head light with the clear style headlight instead if the milk bottle type the earlier SD trucks came with.
The '03 style are cheap on rockauto.com
2001 Ford F-250 SD CCSB 7.3 PSD - AIS Intake, Zoodad,
MBRP 4" XP Series Exhaust w/ Muffler, HD4R100, 26 row Trans Cooler, Fumoto Valve,
285/75R16E BFG AT KO, Pioneer AVIC-Z130BT Nav, BOYO VLT-422C Back Up Camera,
Scangauge II, Glowshift 3 Gauge Pod (EGT,TFT,Boost), PHP FU Chip, Huskyliners, Huskyliner Mud Flaps, Warn Premium Hubs, Riffraff Boots/Clamps/inserts
Dyno'd at Mo's Speed Shop 11/3/12 - 307rwhp / 651rw ft-lbs <<<--- On PHP 120Race tune
BryceB is offline
post #5 of 22 Old 06-22-2014, 06:06 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I'd like to 05-07 or 08-10 my whole front end, my dad has a 6.4 and his is exact same color as my 01, so finding a white truck with a good front clip can't be to hard
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 22 Old 06-22-2014, 06:44 PM
Nice job. Wanting to upgrade my 1999
bertieb is offline
post #7 of 22 Old 06-22-2014, 09:01 PM
700hauler's Avatar
Really? No modding? Im assuming you either had to replace the header panel or cut the stock one to fit those lights. I wouldn't quite call that "no modding"
700hauler is offline
post #8 of 22 Old 06-23-2014, 07:44 PM Thread Starter
Harley Headlights are so loose and sloppy they probably did just fit right in. Ugly too. But glad he made them work.
post #9 of 22 Old 06-23-2014, 10:26 PM
700hauler's Avatar
uhhhh. Really? Most would say that about the lights you used. I hope you realize how ridiculous that sounds.
Good job on the light swap and minor modification to make them fit properly. Turned out good....but comparing the ones you used to the Harley OE style headlights I believe most would agree your above comment couldn't be more off base.
post #10 of 22 Old 06-24-2014, 05:12 AM Thread Starter
I didn't post my photos for some jerk to insult them and say how theirs are better. Treat others as you want to be treated yourself is what i grew up learning. If you like throwing insults at other peoples work then be prepared to get insults at your own work. Nobody should be insulting other peoples efforts, but I guess thats what makes ZackMcF feel good about himself.
