Questions about starting a truck after sitting 2 years - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-21-2014, 08:13 PM Thread Starter
I would appreciate some advice from those that have experience with the 7.3 Powerstroke.
I'm buying a truck that has been sitting for about 2 years and I need to know what to possibly expect, what I should be looking for and any preventative steps to take.
It's a 1999 F250 7.3 with a build date on the VIN tag of 1/99.
It's being sold as-is with a bad transmission. (It has the ZF-6Speed).
Actually, the transmission is in pieces in the bed of the truck. Someone took the entire gear set, rings, etc.. and disassembled the transmission completely and never put it back together again.
The owner said the engine was good (205k miles) and just needs a new tranny.
My questions about this truck that has been sitting for 1-2 years:
1.) Once I put a new transmission (clutch), etc.. new batteries, etc.. back in the truck, what else needs to be replaced BEFORE I attempt to start the truck ?
2.) Aside form an oil/filter change, Should I also drain the fuel tank and replace the diesel or is the fuel in the tank going to be ok ?
3.) Should I add a fuel additive (if so, which one) ?
4.) Should I expect the injectors, glow plug, etc... to give me any problems ?
5.) Is there anything else I need to consider to be looking for ?
Thank in advance
Mike Nelson
Denison, Texas
logic2 is offline
post #2 of 4 Old 06-22-2014, 01:09 AM
ZackMicF's Avatar
Quoted: 30 Post(s)
yeah id just change all the fluids in the truck, i'd drain the fuel and put in a fuel additive for sure, i dont think you'll have any injector or glow plug issues, just dont crank on it for a hour straight, give it break if she dont start,
id use some of these in the tank, i do on the regular
Stanadyne Performance Formula Injector Cleaner 43564
Stanadyne Performance Formula Fuel Additive 38565
01 F250 7.3 CC SB 4X4 THE MOST BADASS 7.3L AROUND!!! too many parts to to list!! wont fit in the Sig. Block!!! but check out the build thread, well worth the time
BUILD THREAD^
ZackMicF is offline
post #3 of 4 Old 06-22-2014, 04:53 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
If you have a way to test the idm before you start it go ahead and do that as well, but I've seen these start on old fuel after setting much longer, I would for sure replace all fluids and give the bowl fresh diesel as well
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 4 Old 06-23-2014, 11:07 AM
jacobm24's Avatar
Not sure if someone else mentioned but I would drain the fuel bowl and put a fresh fuel filter in and clean out any sh1t that may be in there
2000 f250 7.3 w/ 103k miles
4" MBRP turbo back exhaust
DIY Intake with AFE big boost filter
Autometer Cobalt gauges (trans, boost,pyro)
PHP Phoenix stock, 40ht,80dd,120race
Wicked Wheel
Harpoon Mod
203* thermostat
Dieselsite coolant filter
Dieselsite IC Boots
Fightin' Texas Aggie Class of 2013!
Petroleum Engineering
jacobm24 is offline
