Quick Hutch Mod Question - Ford Powerstroke Diesel Forum
post #1 of 17 Old 06-21-2014, 12:33 PM Thread Starter
Hey guys,
A blown brake line has me dropping the tank to get it fixed and I figured this is a perfect time to do the Hutch/Harpoon Mod. Did a little research and decided to just buy a pre made kit (save on time). Will this kit from Strictly Diesel work? Anything I'm missing. I know I will have to buy a pre pump filter, I figure ill just get a cheap inline filter from NAPA. Let me know. Thanks!
Also, any advice on draining 3/4 of Biodiesel from the tank would be helpful
Ty_Deschaine is offline
post #2 of 17 Old 06-21-2014, 02:07 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 21 Post(s)
Feedback Score: 12 reviews
Originally Posted by Ty_Deschaine View Post
Hey guys,
I don't have any advise for the hutch mod... But just siphon the fuel out of the tank
Sent from AutoGuide.com App
2017 f250 platinum
Deleted at 8k miles.. trying to be patient waiting for custom tunes...
mts678 is offline
post #3 of 17 Old 06-21-2014, 02:18 PM
ZMANN's Avatar
Quoted: 1894 Post(s)
i wouldn't want just a cheap inline filter if it's the type I am thinking \
it has the potential to clog fully with minimal debris unlike the large units Driven Diesel Fuel Tank / Pre-Pump Kit
and get the tank to empty because even a few gallons makes it a pain IMHO
doing the harpoon mad also ?
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #4 of 17 Old 06-21-2014, 02:32 PM
sbluke55's Avatar
Quoted: 622 Post(s)
Garage
That will work. Don't get an inline. Get an filter base part number 4770 and filter 3405. You will also need new fuel line from the tank to the pump. Use hose clamps instead of quick connects at the pump and tank. You need to get barb fitting for the filter base also.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #5 of 17 Old 06-21-2014, 03:10 PM
I used their kit and the filter:
Might have saved a bit piecing it together but not worth the effort in my eyes.
Draining the tank, suction hose and lots of buckets?
I bought a new fuel umbrella, mine was in pieces in the bottom of the tank, and the on/off valves for the filter.
2001 CCSB 2WD
222,000 miles and counting
Hutch, Harpoon, Zoodad mods
'05 Grill & '03 Headlights
Pretty much a daily commuter and occasional horse trailer puller
Banger is offline
post #6 of 17 Old 06-21-2014, 03:24 PM
Quoted: 184 Post(s)
Feedback Score: 3 reviews
You really don't have to go to those extremes though. All you're replacing is the plastic screens in the mixer. I have had this simple screen (actually finer than what it replaces) for a number of years with Zero problems. I also like the ability to spot water in the polycarbonate bowl and know the state of things at a glance...
NoRalPh is offline
post #7 of 17 Old 06-21-2014, 04:06 PM
heykw's Avatar
Tell us more about your setup
Where did you get it?
How much was it?
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #8 of 17 Old 06-21-2014, 04:10 PM
ZMANN's Avatar
I run those on all my PWC's but in a much smaller barbed fitting they were OEM on a few Polaris models so I hunted them down for all My Yamaha's LOL they work great
where did u find that ??
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #9 of 17 Old 06-21-2014, 04:28 PM
Quoted: 21 Post(s)
You may want to get a tool to release fuel lines from tank assembly. I think its a cheap plastic tool. I just made do with a screw driver.
The Next Level is offline
post #10 of 17 Old 06-21-2014, 06:18 PM
early99psd's Avatar
Quoted: 14 Post(s)
I used the kit from strictly diesel, very nice and had everything. I also ran the fuel tank down to empty on the gauge, the ran a hot wire to the fuel pump and opened the drain on the fuel bowel to empty the rest. There still was about 4 gal of fuel left.
MB HPOP, PHP Hydra, AFE stage 2, 4" turbo back exhaust, gutted cat, ford reman trans, JW valve body, 6.0 trans cooler, EGT trans temp boost gauges, Hutch and Harpoon mod, riffraf FRx, Pro Comp leveling kit, 1" zone shackels, 08 rear diff cover, 315 Toyo AT2,
early99psd is offline
