TAPE to AUX conversion w/ receptacle - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 11 Old 06-19-2014, 05:19 PM Thread Starter
GeorgiaStrokin's Avatar
Quoted: 8 Post(s)
has anyone opened a factory broken turd 6 disc radio and re-routed the tape to a female receptacle for aux in? i am wanting to cut the tape reader head wires (3) and hard wire them to a female plug which could be conveniently located in the "trash bag holder" and then i can use the common male/male plug to listen to my phone/mp3 player/etc. i plan on sticking the metal tape deck down so the radio thinks there is a tape installed at all times yet still being able to keep the take flapper door shut. i am also thinking of capping the hot wire to the tape deck motor so that it doesnt run while in "tape" mode. anyone see any problems?????
GeorgiaStrokin is offline
post #2 of 11 Old 06-19-2014, 05:58 PM
BryceB's Avatar
Quoted: 2 Post(s)
I had a PIE adapter that hooked in where the CD changer hooked on my factory radio.
I still have it... Make me an offer.
2001 Ford F-250 SD CCSB 7.3 PSD - AIS Intake, Zoodad,
MBRP 4" XP Series Exhaust w/ Muffler, HD4R100, 26 row Trans Cooler, Fumoto Valve,
285/75R16E BFG AT KO, Pioneer AVIC-Z130BT Nav, BOYO VLT-422C Back Up Camera,
Scangauge II, Glowshift 3 Gauge Pod (EGT,TFT,Boost), PHP FU Chip, Huskyliners, Huskyliner Mud Flaps, Warn Premium Hubs, Riffraff Boots/Clamps/inserts
Dyno'd at Mo's Speed Shop 11/3/12 - 307rwhp / 651rw ft-lbs <<<--- On PHP 120Race tune
BryceB is offline
post #3 of 11 Old 06-19-2014, 06:01 PM Thread Starter
Quoted: 8 Post(s)
those are a 2 step ordeal since i would have to run a female 3.5 to male rca adapter right?
post #4 of 11 Old 06-19-2014, 06:23 PM
BryceB's Avatar
Quoted: 2 Post(s)
Correct. I used it like that first with an XM radio and later my phone. I guess I used it with a Male 3.5, but if you wanted a cleaner set up, a female 3.5 with a male to male 3.5 patch cable would work.
Here's a pictures of it.
BryceB is offline
post #5 of 11 Old 06-19-2014, 06:35 PM Thread Starter
Quoted: 8 Post(s)
how much? im not a fan of offers
ZMANN likes this.
post #6 of 11 Old 06-19-2014, 06:43 PM
BryceB's Avatar
Quoted: 2 Post(s)
Looks like they go for $55 on ebay... How about $20 plus shipping or you can pick it up if you're down my way (between Woodstock and Acworth)
BryceB is offline
post #7 of 11 Old 06-19-2014, 06:56 PM Thread Starter
Quoted: 8 Post(s)
sold! pm sent. will pick up.
post #8 of 11 Old 06-20-2014, 03:45 PM
GOODOLEBOYZ250's Avatar
Anybody else got one.
2001 f250 7.3 auto... sniper 175, 80 percent injectors(for now)., garrett super 100, built trans, diamond eye straight pipe 4 inch , isspro ev2..gearhead tunes..bellowed pipes..ebpv delete..6637 filter..plus more to come..
GOODOLEBOYZ250 is offline
post #9 of 11 Old 06-20-2014, 05:36 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Hell I live rite near Woodstock and acworth and would have picked this up if I knew
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #10 of 11 Old 06-25-2014, 06:37 PM Thread Starter
Quoted: 8 Post(s)
ok. bryceb is awesome to deal with and i have an update. i figured out that this was the way to go if you dont have steering wheel/rear controls for your radio. the pie adapter has female rcs plugs and you can buy 3.5 or whatever adapters online to mate to the pie adapter. install is as fast as 5 minutes or as long as you want to take flush mounting the receiver headphone plug of your choice.
now the bigger problem: i need a source for info on which ford oem radios for 99-03ish that are capable of steering wheel AND rear controls. once i find this out, i can buy one that doesnt have 6 disc turd player that always are broken and then add an adapter. please post info if you can help. im thinking of looking at lincoln radios since they mostly had steering wheel controls on the navigators. boy id like one of those wood steering wheels also...
they arent showing an in dash single disc! FRICK!
