Truck wont start? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-19-2014, 12:57 PM Thread Starter
Truck wont start?
Truck started up fine but was shaking during idle and while driving down the road. While driving it died. It will turn over but will not start. A local mechanic said the PCM might be bad. Any thoughts on whats wrong?
WhiteSlush is offline
post #2 of 8 Old 06-19-2014, 12:58 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
CPS possibly. Unlikely that its the PCM. Scan it for codes
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
The Following User Says Thank You to Dave For This Useful Post:
WhiteSlush (06-19-2014)
post #3 of 8 Old 06-20-2014, 05:21 AM
Quoted: 172 Post(s)
Feedback Score: 3 reviews
My usual No Start -
WTS Light? - do you get it when you first roll-on the key? (shows the computer is running)
Do you see cranking rpm on the Tach? Do you have a spare CPS to try?(here you should have posted the yr of your truck it May/May Not show cranking rpm)
Is there fuel in the fuel bowl now? Does it refill after cranking? (open the drain level to check)
Can you hear/feel the pump running (below the dr seat, against the framerail)
Could the fuel gauge be giving a bad reading? (Below 1/4 tank?)
Is it cranking fast enough? - it won't even TRY to start if cranking too slowly.
NoRalPh is offline
post #4 of 8 Old 06-20-2014, 05:04 PM Thread Starter
Originally Posted by NoRalPh View Post
My usual No Start -
Thanks for the reply,
I do get the WTS light, no cranking on the tach (2001), there is fuel in the bowl, its cranking normally. Im taking it to a local diesel mechanic monday to have them scan it.
post #5 of 8 Old 06-20-2014, 05:39 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I would try swapping the cps first, takes 10 minutes and has a plug, only tool required is a 10mm wrench
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 8 Old 06-21-2014, 12:52 PM Thread Starter
I replaced the CPS but still no start.
post #7 of 8 Old 06-21-2014, 03:28 PM
Quoted: 172 Post(s)
Next, you could try disconnecting the plug on the ICP sensor to set a default value for the IPR to run with (it will set a new code though so be sure to tell the mechanic you did this).
Did you check the plug and sheet metal nut going to the IPR? That nut can vibrate off and allow the solenoid going over the valve to slide around. The wires going to the IPR can get brittle, crack, and short together. Make sure the plug & wires look in good shape.
NoRalPh is offline
post #8 of 8 Old 06-28-2014, 12:35 AM Thread Starter
It was the IDM
